ix SD fic 2150's base map needed
Need a speed denisty base map for first start up.
evo ix fic 2150's egr delete omni 4bar ait (using fuel temp) thanks |
you cant just ask for a base map and expect it to work.. you need to give your entire mod list since SD relies 100% on VE tables for tuning. even then you will need to fine tune it so it runs smooth. recommended you use the 2.0 3d tables for full resolution.
i was just hopeing to get a map to fire it up and let it idle check for leaks and what not.
aarron wont be back til wednesday, i guess i'll wait a day or two more. thanks it was a long shot. |
download the rom from tephra v7 thread for your rom id and SD .. the roms are already setup for it and will use the fuel temp as IAT by default.. then set the injector scaling to 1329 for e85 or around 1700 for 93oct.
it will run without any tuning as long as the injector scaling & latency are set and the map sensor scaled properly in the MAP ve calibration table.. the roms on the thread are already 80% setup so u can flash and fire the car up after scaling injectors.. |
thanks for the help, i got the map now as far as the scaleing/latency
1720 3.72 2.088 1.44 1.08 0.84 0.672 0.552 This is what was on the map, i just changed the scaling to 1720. hope this works. |
Originally Posted by kanyonkid
(Post 9159011)
1720 3.72 2.088 1.44 1.08 0.84 0.672 0.552 This is what was on the map, i just changed the scaling to 1720. hope this works. 3 1.488 0.936 0.672 0.504 0.384 0.36 be sure to set the immobilizer also or the car wont fire. |
How is the idle on the Fic's 2150's on SD & e85?
Originally Posted by Dragking2189
(Post 9159079)
these injectors kick ass.. they are great.. but if you run them on pump gas 91-92-93oct etc.. you should patch your rom with the IPW minimum code by tephra so you can control them and your afr better. on E85 it will not need done though. 2150cc fic are identical to id2000, except id2000 go through more thorough testing before sold. with that said i recommend the fic price for price. they are both Bosch injectors and share the same spray pattern. |
Originally Posted by tscompusa
(Post 9159034)
use these as a base starting point for latency on those injectors.
3 1.488 0.936 0.672 0.504 0.384 0.36 be sure to set the immobilizer also or the car wont fire. immobilizer is 0000 change this to 56D2 or is it ECU periphery 0 Hex shows 50DA change to 0x56D2 ? |
set it to whatever the stock rom was.. or just go to the periphery and set the immibilizer to 0 to disable it for now.. since its just a idle rom.
henry,
I should have a map to send here shortly man. aaron |
Originally Posted by JohnBradley
(Post 9161008)
henry,
| All times are GMT -7. The time now is 02:59 PM. |
