how to wire clutch switch
one wire goes to chasis (neg.) and the second directly to ecu pin ? should there be any resistor, relay, fuse or something ?
and also, when the clutch pedal is pushed down, ecu pin should be grounded or vice versa ? |
I have this second wired directly to ECU and it works like stock. Nothing else I didn't do.
what about second part of my question
I didn't do anything else
Just wire the positive wire to the ECU and if you're worried about the ground, run a wire to the firewall or somewhere to ground it close by. You should be good then.
