-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   ECU flash doesn't recognize ROM (https://www.evolutionm.net/forums/ecu-flash/564725-ecu-flash-doesnt-recognize-rom.html)
pshooter Jul 12, 2011 09:57 AM
Picked up my open port 1.3 cable. I read my ECU in evoscan. When I try to read the hex file into ecu flash 1.3 or 1.42 it doesn't recognize the file.
Any suggestions?
dparrish Jul 12, 2011 05:50 PM
Post the rom file here and someone (me) will take a look.
Is there a reason for using evoscan to read the rom instead of ecuflash?
tscompusa2 Jul 12, 2011 05:54 PM
most likely you dont have the XML file for that particular rom on your computer in Program
Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
AndyCT9W Jul 12, 2011 08:49 PM
This might work. Try to open the file and use the option for developers only, inherit the evo 9 base definition then add all your details that you can (you might not know a couple of them). Then hit finish and look at the rom info provided. Look at the internal Id and that should be the XML you are missing. Then search or ask for the XML file on here.
I am going through exactly what you are right now. And this got me a bit further, I just wasn't able to get the complete XML file I needed.
AndyCT9W Jul 12, 2011 08:51 PM
When you get the XML file you need to go into openecu/rommetadata/Mitsubishi/evo (i think that's the location, at work on iPhone sorry) and put the XML file in there.
dparrish Jul 12, 2011 10:46 PM
If you can work out the rom id yourself, there are a large amount of ecuflash XML files at http://code.google.com/p/ecurom/sour...tsubishi%2Fevo
jmcmill3 Jul 13, 2011 06:47 AM
that fixed my issue, thanks...
wamang Feb 5, 2015 05:06 AM
map did not show mivec setting
hi:
I use ecu flash to reading my ecu but the mivec adjusting cannot show out
can any one help ? mine is evo wagon ct9w manual 6 speed
thankyou
