General non-information about factory ALS
Factory ALS is a bit of a myth, but Ive seen it working in various USDM cars.
Ive been searching for a long time, and people have integrated it in various ways to the USDM roms, which none have been revealed. . The disassembly thread died long ago .. I will donate, pay etc, just trying to acomplish this :) I have my own setup that is similar in function the OEM stuff, if the ROM functioned, I would like to tweak my hardware! |
i think the consensus was that for proper factory ALS u need the factory hardware first.
That consensus aside, the rom still needs to function correct? I'm only concerned about the rom in this thread.
You can do it either way. The factory parts do make it better for sure.
Aaron |
the usdm roms do not have als code. as jb said, if you want als, there are two choices.
1) get factory als hardware, hook it up properly, and run an als rom. 2) do your own homebrew als hardware. if someone can come up with effective homebrew hardware, i'm sure that someone would step up to write any needed code. i think there is relatively low interest thus far because people can build a few psi by retarding timing. |
Ok, well, I do know for a fact that JB/Evors had a USDM rom running with ALS on factory hardware, and Evors even said he would post a tutorial several times if somone made him the table to fine tune.. I dont know how to do that, but I would like to experiment to say the least. using JIC-npt fittings is my solution and it keeps the parts availability local.
Originally Posted by evoRS06
(Post 9219857)
I have posted in this thread and others that as sone as someone that can make me the table that I want to fine tune my anti lag I will post up a how too. I have working anti lag now, but I would like to refine it. I am using a usdm 9 ecu on a usdm 9 with sas valve and lines, everything else is factory usdm. Like I sad, anti lag can be done, but my request for the table has, I guess, been ignored or considered not a priority. So I will wait patiently
Originally Posted by 211ratsbud
(Post 9593234)
The only successful instance I've heard of running factory ALS hardware on a USDM Evo was one where a JDM ROM was used. I suppose its also possible to setup some sort of manual control over the factory ALS hardware as well. |
Not disrespecting your intellect, but the video was posted by jb, and that claim was made in the same thread if not same post.
Jdm rom would need repinning or adressing correct? and would not be obd 2 capable. I'm still very interested in this, I've been on ebay.co.uk for a while but noone yet has shipping to the us, that I've seen Could it bee a simple as referencing the low oct ign and fuel map on overrun? and opening the solenoid... |
(Post 9593357)
Jdm rom would need repinning or adressing correct? and would not be obd 2 capable. I'm still very interested in this, I've been on ebay.co.uk for a while but noone yet has shipping to the us, that I've seen Could it bee a simple as referencing the low oct ign and fuel map on overrun? and opening the solenoid... A JDM ROM does not require rearranging the USDM ROM ECU inputs. It does run OBD2 routines, but not all the ones used in a USDM ROM. Some engine control routines would not work properly on a USDM car because of some inputs and outputs being used for different things. For instance, the JDM Evo 9 ROM expects to see manifold intake temperature on pin 96, but on a USDM Evo, pin 96 is hooked up to a fuel tank temperature sensor. This could cause a bit of heartburn with the fallback SD implementation built into JDM Evo 9 ROMs. |
Factory ALS code is also at 88580014 rom and that rom does not use map or MAT sensor. Is there some other inputs/outputs that are different between JDM and USDM?
Originally Posted by donner
(Post 9593415)
(Post 9593357)
Ok, well I would def like this to new ecu controlled. My best bet is to get hardware sorted, and search for code writers. Basically, I am going to take a metal bpv, open the reference port to atmosphere, and plug the piston side bleeder hole. run two steel lines taken from my scuba diving cascade set up and npt those into the mani.
(Post 9593357)
I too have been waiting for several years for this box of parts to work. I'm willing to pay for someone to write the code. |
Whats mlr? Mitsubishi lancer register?
