Scaling 1450's help
Running FIC Blue Max 1450's with a Map 2.3 10.5:1 motor cams ported everything blah blah blah.Here are my results can someone chime in what you would change if any to make the results better?
Scaling 860 4.69 2.880 7.03 2.520 9.38 1.728 11.72 1.368 14.06 1.248 16.41 0.984 18.68 0.840 low trim -5.586 mid trim 2.834 |
pump gas or E85?
Originally Posted by freddie@spec-ops
(Post 9599030)
pump gas or e85?
I am going to be honest with you... I wouldn't change anything as the trims are rather close... trying to get the trims perfect will drive you crazy!
Running FIC Blue Max 1450's with a Map 2.3 10.5:1 motor cams ported everything blah blah blah.Here are my results which are about as close as I can get it {thumbup}
Scaling 943 4.69 2.784 7.03 2.448 9.38 1.608 11.72 1.344 14.06 1.244 16.41 0.984 18.68 0.816 low trim 1.66 mid trim 1.85 |
Originally Posted by Freddie@Spec-Ops
(Post 9599510)
Very nice. You should add it to the injector scaling and latency thread
| All times are GMT -7. The time now is 01:07 PM. |
