Tephra V7.1 and high load
Guys,
have 2006 EDM EVO9. Tephra V7.1. On idle I have logged by EvoScan load around 200. Seems to high to me. Anything I could check for being non-working? Thanks! Anton |
Thats pretty high but cant be correct. I was logging my car tonight and for 10 minutes at idle it was between 26-28. probably just an incorrect evoscan formula somewhere.
Which load are you using to collect the data from? Load 1byte or load 2byte? You should try using load 1byte if you arent already using it. |
Originally Posted by KOOLER
(Post 9617252)
Guys,
figured it already, mut requests were changed from what was in tephra's original firmware.
shows proper loads now. |
MUT tables set up correctly so load is OK. Thanks to everybody!
