few quirks, multiple CEL's :(, idle afr swing
The following are codes i cannot get rid of, and I was using the OBD circuit bypass test to avoid the CEL illum. However it is insepction time here in the great empire state for me, and I dont even understand why these codes would be on, if the car seems to run ok, however I do have erradic idle AFR swinging.
Ive ran 7-13* at idle. 06 rs, hks cams, fp 71hta with 84 cover and intake tube. pte 1000cc injectors, omni 4 bar buschur dp and megan 02.. v7 rom, with mrfred's ISCV defs Diagnostic Codes:Vehicle speed sensor speed reads fine in my dash and via ecu Barometric pressure sensor???? Injector circuit Ignition coil. Ignition circuit Seems like a problem associating, the maf or.connector .. also read that evoscan sucks at dtc reliability .. pointers ? |
| All times are GMT -7. The time now is 08:29 AM. |
