AEM WB error in evoscan 2.7 HELP
Hope someone can help, my wideband worked fine then a day later im getting this error. AEM ERROR: conversion from string "1v.7" to type "Double" is not valid. the "1v.7" will change as the numbers on the wideband itself changes. Also in evo scan it will come up right for a split second then nothing. i checked the wiring, tried another laptop, uninstalled and reinstalled evoscan and still the same error. Any help would be great
change your "Regional settings" to USA in My computer->control panel
tried that still the same error any other ideas?
im guessing no one has had this problem
which OS you use?
soooo bummppppp.. any solutions?
