-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   NEED HELP ASAP! Just tried to change idle and now car won't start! (https://www.evolutionm.net/forums/ecu-flash/589307-need-help-asap-just-tried-change-idle-now-car-wont-start.html)
darkside4G63 Dec 17, 2011 10:51 AM
Yesterday I went into ecuflash to change up idle a little and as the reflash was running it popped up an error in the middle of the process. I swapped USBs and flashed it again and this time it went through. I tried to start the car and it just cranks. I flashed in other known good maps with not errors and still the same thing. I have a mini battery so I thought that low voltage might be an issue so I left it on a battery tender. Tried again this morning and it still just cranks even on several different good maps. I disconnected the battery for over a hour, hooked it back up, went back and flashed it again and still It just cranks. Please help. This is my main vehicle and I'm really in a bind. Thanks in advance
Evoloved Dec 17, 2011 12:13 PM
Maybe your immobilizer code got left out I know its a dumb thought but maybe
darkside4G63 Dec 17, 2011 01:26 PM
Hell I'll try anything at this point. I know you can turn the immobilizer off in the periphery settings. Anyone know which one it is?
Spec-Ops1 Dec 17, 2011 01:43 PM
Check your ignition fuses the one by the battery and under the dash...
Evoloved Dec 18, 2011 09:11 AM
periphery settings 0 FAA bit 3
