-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   Tuning MAPerformance Rev3 w/FB TB/Ported stock log mani Q's (https://www.evolutionm.net/forums/ecu-flash/599062-tuning-maperformance-rev3-w-fb-tb-ported-stock-log-mani-qs.html)
Raceghost Feb 19, 2012 11:45 PM
Hello gents and lady's. Have a few tuning qeustions for all you guys and the guru's if I can... :confused:
Working on a build. From the tuning department, all suportming mods + the title of the thread. Tuned currently with all suporting mods. We are now adding the Rev 3 Intake plenum, 70 mm Throttle body, Ported mani, and I changed my stock routed 3" exhaust, over to a freer flowing jdm HKS. Plus HKS ignition amp, and an earth kit to finish off the ignition upgrade.
Tuning questions... More flow, more flow, more flow.
Where should I start, Timing? Fuel? Any little things outside the big 3 (timing, fuel, boost) that one would want to look at? :helpme:
Thanks in advance. {thumbup}
ChrisCarey Feb 20, 2012 08:27 AM
Always make sure AFRs are safe, adjust to desired boost level, and then add timing. Best of luck!
