-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   Pop's & Bang's Map...Is it BAD? (https://www.evolutionm.net/forums/ecu-flash/636711-pops-bangs-map-bad.html)
jameswwt Nov 19, 2012 06:17 AM
Hi,
ive mapped my current map for pops & bangs by retarding the timing (-) on lower load cell.
The sound is truly awesome but will the exhaust temp sky rocket and is it bad for the engine?
Thanks
Biggy VIII Nov 19, 2012 10:04 AM
I can not tell how bad is it in real world, but I would be definitely concerned about exhaust valves, the more you retard timing.
Could you share these parts of your timing and fuel maps?
Raptord Nov 19, 2012 10:24 AM
It could potentially be hard on the exhaust valves and turbo during repeated, prlonged use.
boosted91t Nov 19, 2012 10:26 AM
There is a happy medium, are you still on a stock bottom end? How many degrees are you going? I've had luck on launch maps retarding timing with it still being a positive number. Ie not going crazy -15 or -20 deg
todd6027 Nov 19, 2012 12:30 PM
the als pops and bangs on stock ecu will not harm your turbo or exhaust valves the ecu goes to -10 only its only activated on overrun ive used it for years on numerous evo 1s to 9s will no ill affects
Raptord Nov 19, 2012 01:03 PM
You can retard past -10 with an ECU patch.
JSPturbo Nov 19, 2012 01:52 PM
With Patch ?? I tried with few roms and patch and doesn´t work, only retard -10º
ROM 96530006
foxbat Nov 19, 2012 02:42 PM
ROM 96530006
It depends what ECU being used:
E9 -20
E7/8 -10
E5/6 -27
foxbat Nov 19, 2012 02:47 PM
Hey Todd, a tricky question, is it possible to set SAS tables to improve in between shifts response rather than pops'n'bangs only?
todd6027 Nov 19, 2012 03:28 PM
drilling the banjos and the holes in the exh manifold between the ports helps
jameswwt Nov 19, 2012 05:10 PM
Thanks Guys for your kind sharing.
Im on -10 retard and the pops & bangs is crazy awesome when lift off or partial throttle...
Hi Todd, thanks for sharing yr experience and say if the exhaust valve seals is toasted what is the sign?
Or do you think its better dont take any risk?
211Ratsbud Nov 19, 2012 08:05 PM
you can get major artillery sounds with air and eliminating the closed loop in the areas you have negative timing/sas running.
jameswwt Nov 20, 2012 02:43 AM
Hi 211ratsbud, what do u mean? Im did not activate any LC/ALS as i just retard the ign by -10 and the sound is crazy.
One thing to share is, the fuel consumption has sky rocket but im not sure about the exhaust temp...
Btw what Overruns mean?
sorry for the noob question...
Biggy VIII Nov 20, 2012 09:03 AM
pops'n'bangs
1 Attachment(s)
pops'n'bangs
dolphin888 Nov 20, 2012 09:53 AM
Interesting idle timing. How does it feel when engine is warming up?
