can't go pass 14psi with grimspeed...
Hey Guys, since winter has hit I wanted to switch from MBC to ecu controlled boost.
With my MBC I was hitting 29-30psi all day on my evo 8 and could adjust it. Now I went to the grimspeed solenoid and I cant get past 14psi no matter what I try. I am currently using the tephra v7 rom. I tripled checked to make sure I hooked up the grimspeed correctly, port 1 going to intake manifold, port 2 going to wastegate and port 3 going to nipple on j-pipe. I went ahead and also replaced the vacuum lines. On to the tuning aspect, at first all I did was change all the values on the BEC tables to 0. Then went to my main wastegate duty table and all the values 50. I started off the run in 3rd gear and hit only 14psi. I went ahead and changed the values to 80 and still hit only 14psi. At that point I knew something is off...I went ahead and changed all the values to 100 jut to see if it made a difference and nothing. I changed the boost adder (psi) tale to 14.7 to see if that would do anything but still nothing. I am not sure what I am doing wrong. Two days ago I was running 29psi, only thing I changed was MBC to grimspeed . Am I configuring something wrong in ecuflash? Maybe the grimspeed solenoid is bad?? Any advice? Here is a picture of my settings: Boost error correction , boost adder, main map wastegate duty, boost desired engine psi, SHLR->SHLL for EBC http://i243.photobucket.com/albums/f...t/scr_shot.jpg Mods on 05' evo: evo 9 turbo megan manifold gsc stg 1 cams br dual pumps exedy twin disk ets fmic tial q bov 3" turbo back exhaust(cat-less) fic 1450cc spoolin-up cop |
Port 3 should go to the J-pipe nipple, Port 2 should go to the wastegate, and Port 1 should be vented to atmosphere or routed into the intake pipe instead of the intake manifold.
Yes I hope that port 1 into the intake manifold is a typo ;)
Your ROM looks ok. Try dropping the "WGDC 100% under this load" to 0 and listen to it at 50% you should hear clicking. This will avoid you some electrical tests. I'd bet it's a mechanical problem. |
sorry , I'm an idiot! Got it to work. Thanks domyz for all your help.
Just to make sure I got this figured out correctly, this is the approach im taking.. I set all the values in the BEC to 0 then I will start working with my main map wastegate duty to get the psi I want. This I will measure by looking at the boost gauge and checking the value. Is there a way to do this through evoscan or a better technqiue then this? Domyz- i know you told me about the WGDC and the values there, do I go off of that and use those values to set the main map wastegate duty values? Also when do I or should I start messing with the Boost Desired Engine 'PSI" table?? |
Couple things.
You should zero out the upward correction. Also make sure you have the MAF IAT WGDC corr. zero'd out too. (when tuning) Next, its best to get a MAP sensor when tuning ECU boost. Also, you have to have a map sensor to run PSI based boost. Last, make your WGDC limit during fault half of your WGDC used to reach your desired boost. or just put 30% |
Originally Posted by NOMIEZVR4
(Post 10518347)
(Post 10518347)
Just to make sure I got this figured out correctly, this is the approach im taking.. I set all the values in the BEC to 0 then I will start working with my main map wastegate duty to get the psi I want. This I will measure by looking at the boost gauge and checking the value. Is there a way to do this through evoscan or a better technqiue then this? Domyz- i know you told me about the WGDC and the values there, do I go off of that and use those values to set the main map wastegate duty values? Also when do I or should I start messing with the Boost Desired Engine 'PSI" table?? Sorry I don't know what you mean. If you are refering to WGDC 100% under this load, I suggest you to start with 0 for part throttle drivability. Otherwise the very useful TPS WGDC correction table won't work. As said by Jay you already should have a omni 4 bar map sensor, or equivalent. The how-to was very helpful for me and don't hesitate to ask questions we'll help. Happy tuning! |
Originally Posted by Raptord
(Post 10518390)
What was the issue?
(just kidding :lol:) |
^^ lol..i hooked up port1 to intake mani
(Post 10518497)
domyz
What I was trying to get to is , do I ever change the values in the Boost Desired Engine 'PSI' table? If so when do I? I did read the "How-To" link you posted but I couldnt find it there. |
(Post 10519999)
domyz
What I was trying to get to is , do I ever change the values in the Boost Desired Engine 'PSI' table? If so when do I? I did read the "How-To" link you posted but I couldnt find it there. You could only set the boost in Main map WGDC while reading your boost gauge, but without any correction it is neither safe nor consistent. |
Originally Posted by domyz
(Post 10520017)
(Post 10520022)
It's not any worse than using an MBC.
Personnally having boost error correction help me sleep better :lol: |
| All times are GMT -7. The time now is 07:56 AM. |
