I'm confused with read/write and tephra v7 mod!!
Hello guys. I have some questions because i cant find the answer anywhere and now i'm confused and i need a help!!!
Firtsly, some infos about my car (evo 9 - rom 88840017). My car is reflashed from another tuner and he put tephra v7 to my car. I start to do some logs and i saw too many knocks and i create some now maps a little more rich with less ignition timing. So now i have some question. 1)when i read my rom i read a hex file only(or and xml file)? 2)when i read my rom i cant see tephra mods! 3)i want to write back my new hex file. So if i write back my hex file, i will lost my tephra mods? 4)when i will write my hex file back to my car,i am also writing and the xml file(stock with no tephra) from ecuflash? 5)how i can read my tephra mods with ecuflash or evoscan?(i dont have his tephra xml file) 6)which program is right to write back my new tune hex file and keep my tephra mods (ecuflash or evoscan)? Thank you for your time. And i hope someone to help me because i want to write back my file today! :D:D:D |
Go to the tephra thread and download the XML file that goes with your rom. You can use evoscan or ecuflash to read and write the ecu.
Originally Posted by ReaperX
(Post 10572034)
If you read my question you will see that I want to write a new hex file and keep the tephra, how I can read my tephra setting from my tuner,...? Thanks guys for the time! |
if you have the correct xml file v7 you will be able see the tephra mods in ecuflash when you download the tuned rom then edit that as you need to and flash it back
Originally Posted by todd6027
(Post 10572206)
now i open the hex file with the original xml file! |
Originally Posted by nikos_paps
(Post 10572218)
if i dont have the correct v7 xml file(bcoz i dont have it)?
pm sent with e mail address
(Post 10572233)
then you wont be able see the mods
If i had the correct xml file i could see the tephra mods? Do you know any way to read my xml file from my ecu? Thank you for your time! |
(Post 10572255)
Now when read my hex file i can see all the tables!
If i had the correct xml file i could see the tephra mods? Do you know any way to read my xml file from my ecu? Thank you for your time! xml files are saved to rommetdata in ecuflash if you look in your laptop my computer/C;/ program files/ open ecu/ecuflash/ rommetdata /evo you will see all the xml files you have , when you download ecuflash it already has some xml files in there but not the v7 or modified ones. |
its in here
http://api.viglink.com/api/click?for...13562892672044 download and open then save the xml second one down to my computer/ C; / program files/ open ecu/ecuflash/ rommetdata /evo |
| All times are GMT -7. The time now is 02:41 PM. |
