-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   Can't edit rom metadata folders (https://www.evolutionm.net/forums/ecu-flash/647021-cant-edit-rom-metadata-folders.html)
Tuxevo Feb 17, 2013 04:15 PM
When I try to copy, paste and save definitions into ecuflash i get a error message saying access denied. What I'm trying to do specifically is add the tefera v5 definitions to rom 88590015. I just switched to the newest version of ecuflash.
boosted91t Feb 17, 2013 04:19 PM
If you are on windows 7, go to properties, security, advanced and then you can edit your user to have full permission to edit those files.
I have also had issues with adding definitions lately so hopefully you have more luck then I did
Tuxevo Feb 17, 2013 04:36 PM
It showing full control, but still not giving me the ability to change anything.
codgi Feb 17, 2013 11:38 PM
What rights does the user that you are running with have? I usually advise people to run in low privilege mode. For tuning with the apps written that don't seem to even run properly if run with a lower privileged user my suggestion is to setup a profile as admin just for tuning. I have no issues doing anything with EcuFlash/EvoScan with that setup in my tuning laptop. Then you have another account with lower privileges for going on the internet.
boosted91t Feb 18, 2013 08:14 AM
I am still leaning towards some sort of block from full permission on your user name or lack of permission on the folder that the roms are located in..
codgi Feb 18, 2013 11:39 PM
UAC is probably enabled I would agree
seymour86 Nov 5, 2013 07:12 PM
Having same problem. I am using windows 7 set as Admin.
Tuxevo Nov 7, 2013 06:37 PM
Sorry I didn't report back sooner. I had to change the settings to take it off read only. I went to the start menu, typed ecu flash in the search bar, the program came up, right clicked on it, went to properties, clicked the "general" tab and unchecked "read only'. Problem solved.
Star Moon Nov 16, 2020 03:52 PM
I figured it out
https://cimg2.ibsrv.net/gimg/www.evo...530365a17.jpeg
This worked for me
