Timing randomly being pulled in upper RPMS
I've been banging my head against the wall trying to figure this out. From 7400 RPMS on up, timing keeps being randomly pulled to 5* from what it is supposed to be set at{7-8*). There is no knock in the logs, AFR is 10.7-10.8. Timing in the logs looks like this:
6-6-6-7-7-7-5-5-7-7-7-5-5-8-8-5-5-8-8-5-5 I've double and triple checked for loose things in the engine bay and tighten every bolt/nut, checked grounds, replaced IAT, replaced cam position sensor, and just replaced the crank position sensor. There are no blown fuses. I've tried a stock ignition, iridium plugs, copper plugs, my mini battery is new as of May-June, and has been on a trickle charger when the car is sitting since day 1. Car was boost leak tested to 35psi with no leaks. I've done multiple compression tests as well and the numbers are exactly what they were last summer. Im out of ideas. Has anyone experienced this before? I can attach logs/rom if someone would be willing to take a look. Car is being tuned remotely by a very reputable tuner, I highly doubt the tune is the problem, but I guess you never know. |
Have you zero'd out all your corrections to ensure one of them isn't playing in the background?
Originally Posted by Benja
(Post 10958159)
Show us a log and why 10.7/10.5 afr
1 Attachment(s)
Originally Posted by todd6027
(Post 10958596)
(Post 10958159)
Won't hurt to zero the rest out just to see, but i don't think it'll fix this one.
(Post 10958596)
Either way, i leaned it out more and we will see what that does. The target afr for the car in general is around 11.5ish on 93oct. I will report back new findings. Thanks for helping guys. |
1 Attachment(s)
Here is a log from tonight with a new rom. Still broke up up top a bit, timing issue still there, no knock. :confused:
whats the eng spec , peak load is late 5600/5700 and 11.1 afr
(Post 10961717)
PTE 6766 CEA, Twin Scroll 1.15 a/r on the hot side Comp280 cams 3.5"-4" exhaust 5" ETS FMIC 3" i/c pipes stock throttlebody stock intake manifold |
(Post 10961717)
http://www.tscomptuned.net/_images/d...n-r/6766-1.jpg Just need to figure out whats causing the timing to scramble. its not the AFR. I leaned the car out to be 11.5 straight across still does it. I think its something to do with the crank trigger plate. |
Turn on FLASH CEL For knock and is it flashing during the pull?
You can have the issue were ecu will pull timing so quick it wont pick up on logger, as well as you can see knock voltage getting high at the point it pulls timing. Have you tried turning knock background noise table up to say 30 and do a pull and see what it does?
Originally Posted by mtuned
(Post 10965552)
(Post 10965606)
i personally think this is something to do with the trigger plate / crank / cam signal. or maybe bad ground or ignition. |
This is a long shot, but the ECU adjusts timing to 5 degrees if it gets the start signal input. Maybe there is some wiring fault/short that causes that input to go "live" at higher rpm due to vibration etc. You could disconnect the pin from the ECU connector as a test and see what happens.
Another possibility would be if the vss is working intermittently and the launch maps are enabled and happen to have 5 degrees in those load cells (I have seen something like this before). |
Tom this is probably also what my Idle dip problem is... remember my timing dropping itself to like 5*? even though we never had that on the MAP. Maybe its the starter signal like someone said? Hoping to find a solution for OP and me :)
