-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   Car won't start after gearbox failure (https://www.evolutionm.net/forums/ecu-flash/678437-car-wont-start-after-gearbox-failure.html)
napolean Dec 19, 2013 10:40 PM
Hi I'm having trouble starting my car after replacing a blown gearbox. It was a serious gearbox failure at the drags.
I was running on e85 and the engine has been sitting for 3 months after which I replaced the gearbox and reassembled everything. The tank was drained of fuel for the 3 months.
I have since filled up with pump fuel and reflashed my pump fuel map back into the ecu for the restart.
Things I have checked so far:
No blown fuses
No fault codes
I have spark
I have fuel pressure
ECU Immobiliser is switched off
Timing marks all line up
I've poured fuel down the cylinders and got it to fire very briefly then it just dies. I have an evoscan datalog which shows some weird things happening with speed and rpm when I am cranking the car.
Is this signs of a crook crank position sensor despite no fault codes and still having spark???
Modifications are:
- 4G63 Block
- Manley 2.3 litre crank
- Carillo Rods
- Wiseco Pistons 9.0:1 CR
- Ported Head, bigger valves, etc.
- Custom Kelford Spec Cams
- Larger alloy Intake Manifold Port matched to head
- 70mm Throttle Body
- 2.5 inch alloy intercooler piping
- 300x600x75mm FMIC
- AMS 950R T3 turbo kit
- Tial Q 50mm BOV
- AMS Fuel Rail
- Adjustable cam gears
- Greddy Profec B Spec II electronic boost controller
- 3 inch turbo back straight exhaust,
- GM IAT sensor in upper intercooler pipe
- Spoolinup SD Harness
- Omni 4 Bar Map Sensor fitted to intake manifold
- 4 inch intake
- spoolinup COP
- FIC 2250 Injectors
- Walbro 255 lph intank lifter pump
- twin Bosch 044 external fuel pumps and surge tank
- -8 feed and -6 return lines
- Quartermaster twin plate 8 leg clutch
- Tephra V7 96531706 V7 SD mapping
http://imageshack.us/a/img401/9848/1vl8.jpg
napolean Dec 20, 2013 02:12 PM
1 Attachment(s)
Attachment 216921
Datalog uploaded.
Bally205 Oct 7, 2015 05:43 PM
Change plugs
georg1970 Oct 8, 2015 05:02 PM
we had the same problem not so long ago - crank sensor was the cause of it so I think you are right.
