HELP! Can't read Evo IX rom
Ok, so I've read all I can find and still can't figure out why ecu flash won't read my rom.
I have a USDM evo 9 that is on a stock map (the updated recall map from last year) I'm using a brand new 1.3U cable, Evoscan v2.9, Ecuflash v1.44. The drivers have been installed and the cable connects via evoscan for logging purposes only it will not read the image via Evoscan or Ecuflash. I talked to my area tuning guru and he says the ROM ID of the update should be 88590017 which there is no deffined XML for that I have found. So I duplicated the 88590015 rom (Stock rom) XML and changed the rom ID to 88590017 hopping it would work. Still no luck. I've also tried running ecu unlocker. I hit the read ecu button, select the evo 9 option, a dialog box pops up: Connect the OpenPort interface to the OBDII port, plug in the OpenPort initialization connector, turn your ignition to the 'ON' position, and then press the OK button to continue. I press ok, [16:04:04.914] EcuFlash Version 1.44.3721 [16:04:04.914] OS Version Windows 7 [16:04:04.914] Qt Version 4.8.0 [16:04:04.927] 63 memory models read. [16:04:04.928] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates [16:04:04.932] 16 ROM metadata models scanned. [16:04:04.932] checksum module "subarudbw" loaded. [16:04:04.932] checksum module "mitsucan" loaded. [16:04:04.932] checksum module "mitsuh8" loaded. [16:04:04.933] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded. [16:04:04.933] patch module "Mitsu CAN RAM Parameter Logging" loaded. [16:04:04.936] flashing tool "wrx02" loaded. [16:04:04.938] flashing tool "wrx04" loaded. [16:04:04.940] flashing tool "sti04" loaded. [16:04:04.943] flashing tool "sti05" loaded. [16:04:04.943] flashing tool "mitsukernel" loaded. [16:04:04.943] flashing tool "mitsukernelocp" loaded. [16:04:04.943] flashing tool "mitsubootloader" loaded. [16:04:04.943] flashing tool "shbootmode" loaded. [16:04:04.944] flashing tool "shaudmode" loaded. [16:04:04.946] flashing tool "subarucan" loaded. [16:04:04.948] flashing tool "subarucand" loaded. [16:04:04.951] flashing tool "mitsucan" loaded. [16:04:05.277] Using interface OpenPort 1.3 Universal TX2IpW7H6d9acfd93fa5a167aede4de89f14f4dd93fa9900 [16:04:05.307] interface close [16:04:05.819] Using interface OpenPort 1.3 Universal TX2IpW7H6d9acfd93fa5a167aede4de89f14f4dd93fa9900 [16:04:05.838] interface close [16:04:06.126] Using interface OpenPort 1.3 Universal TX2IpW7H6d9acfd93fa5a167aede4de89f14f4dd93fa9900 [16:04:06.148] interface close [16:04:15.445] using metadata XML ID read_mitsum32176f6boot from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_mitsum32176f6boot.xml [16:04:15.739] Using interface OpenPort 1.3 Universal TX2IpW7H6d9acfd93fa5a167aede4de89f14f4dd93fa9900 [16:04:18.914] sending init sequence 1 (0001) [16:04:22.164] sending init sequence 1 (0003) [16:04:25.407] sending init sequence 1 (FFFF) [16:04:28.656] sending init sequence 1 (F0F0) [16:04:31.390] no response to any known code [16:04:31.393] interface close |
Try to use an older version of ecuflash. Try 1.29. That one worked for me l read it. I don't have the XML file but I got it to read my Ecu at least. I also had Ecu unlocked running in the background.
Also make sure your voltage is good. I had mine plugged in to a battery charger while I read it. |
Originally Posted by johntrav
(Post 11139885)
Originally Posted by Evol Knievo
(Post 11139887)
What Rom where you running? Where you on the update?
That's what the identifier says. I read that with evoscan. But idk if get is right. From what I read that's an Evo VIII identifier and I have an Evo IX like you. I had no problem with evoscan reading my Ecu. The problem I have is openin it in ecuflash. I always get the setup rom window |
try it with the battery jumped to another running car. I cannot ever flash my evo without having another car connected. probably a weak battery.
It's not the battery. Its its at 12.6 volts . This is a more unique situation that has to do with the updated rom.
try eng running , cable connected to obd port and flash connector , unlocker running and ecuflash open , hit the read button
1 Attachment(s)
Ok so I downgraded to ECU Flash 1.43 and was able to download the image but when I try to open it this is what I get.
1 Attachment(s)
Here's the file. Can anyone else read it? All I really need from it is my engine immobilizer and the ROM ID would be nice to know for reference sake.
I sent you the immobilizer via FB. Romid is 88590016
| All times are GMT -7. The time now is 09:26 PM. |
