-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   Evoscan - Can't Log Speed (https://www.evolutionm.net/forums/ecu-flash/687779-evoscan-cant-log-speed.html)
ehall20 Apr 6, 2014 02:12 PM
I tried searching the forums for an answer, but all the results I was able to find had to do with setting up Evoscan's baud rate :lol:.
I've gotten almost everything I need to log working in Evoscan (AFR, 2-byte load, JDM MAP, etc.). The one parameter that I can't get to log for the life of me is "Speed". Whenever I select it as part of my logs, all I get are measurements of 0. I'm using Evoscan v2.9.0023 and ROM 88590015. The Request field for speed is listed as "2F" and the function is "1.2427424*x".
The only tinkering I've done with XML files has been to get 2-byte load and JDM MAP logging set up. If I understand correctly, the Request field in Evoscan is referencing that cell in my MUT table. When I pull up the MUT table, however, cell 2F is listed as "2A..." instead of a 4-digit hex number like most of the other cells.
Is cell 2F supposed to be listed this way, or is this possibly the reason I'm unable to log speed in Evoscan? I'm sorry if this is a stupid question, I'm still in the process of reading everything I can to try and wrap my head around this software.
ehall20 Apr 6, 2014 02:17 PM
1 Attachment(s)
Sorry, I forgot to add this in my original post. Uploading my ROM for reference.
jrainwater Apr 7, 2014 01:49 PM
It won't show "speed" unless you are logging "gear" at the same time correct?
ehall20 Apr 7, 2014 06:00 PM
Didn't know I had to log gear as well, that fixed it. Thanks!
jrainwater Apr 7, 2014 07:05 PM
No problem, I'm glad it worked for you. My evoscan tells me if I try to log speed without gear that I need to click gear. Yours didn't tell you that? A little thing pops up and says hey log the gear too dummy lol.
ehall20 Apr 7, 2014 10:33 PM
I don't remember getting a message like that, but it's also entirely possible I overlooked it at the time :lol:.
