nlts problem revs
hi guys,
i'm owner of evo9gsr 6speed, european with tephra v7. when i activate NLTS, it's working perfectly but i have a problem with stationary rev limiter(if we can call the problem with this name) i try to explain better: when i'm in MOTION(not hold,) ,one gear insert but with clutch all down and about 3000/3500rpm i push all gas, rev remain limited around 4000,so is impossible hits the limiter.can you find here the video https://www.youtube.com/watch?v=fL-Z...ature=youtu.be what is strange is I can hit the limiter in these 2 cases always during motion: i push gas about rev5000 or 2000 i push gas neutral gear at all rev it look like i have the range limit also to go up with gears and not only down if i disable NLTS mode, the problem of stationary rev limiter end. could you help me? |
Attach your rom and I'll take a look.
Originally Posted by 10isace
(Post 11179811)
please give me your mail which tables do you need? |
Originally Posted by besk
(Post 11179950)
thank you man please give me your mail which tables do you need? Just send me your current Rom. I'll let you know if I see anything. |
