Easiest way to log load without using tephra v7?
Hey guys, I'm in the process of tweaking some of the fuel maps on my evo 9. I haven't done much tuning since I sold my evo 8 years ago. The problem I am having now is that I can't seem to get a good load log from evoscan. Am I selecting the wrong load category to log? Or do I have to convert to tephra v7 just to be able to log load?
thanks!! |
try 2 byte load you might have to edit the mut table to get it to work info below
https://www.evolutionm.net/forums/ec...ight=byte+load |
i'm runnin an 8 logging 2 byte load without tephra mod.
definitely do the 2 byte load. 1.find out what your rom id is. 2.add the MUT table into your ecuflase base xml 3. double and triple check the MUT table address. i've mentioned on here before that the table address was wrong for my id on the eculogic page. BUT don't worry. if that's the case with you, double check the "official 2 byte thread" for the correct address. my rom id's mut table was correct in the thread and wrong on the site so go figure. 4.anyways once you get that setup then add the correct info for the fields for 2 byte load and then you should be all set. pm me if you want even i can go into greater detail need be. i just need your rom id to be able to give you correct table address information and also what xml files you should modify. :mitsu: |
