Hitting fuel cut - multiplier setting not working?
2 Attachment(s)
I've been having problems hitting fuel cut at the 'Fuel Cut Load x1' value, even though (I think) I've got the 'Fuel Cut Multiplier' setup to use 'Fuel Cut Load x2'.
Attached is what my values are set to. ROM is 90550701, car is Evo 7. Any ideas what I'm doing wrong? Attachment 235144 This is what my XML looks like: Code:
<table name="Fuel Cut Multiplier" category="Global Fuel Settings" address="11ac6" type="2D" level="2" scaling="Hex16"> |
I was having some confusion over this recently myself, are you on sd? I believe you need to have the load cap fuel flow eliminator and load cap airflow setting to 0x9 if it's currently set to 2ba1... hopefully someone comes on to confirm though.
but then I read on another thread that if running sd it should stay as 2ba1... I haven't had a chance to test and see.
try 3814 for load boost address instead of 3614
I set them to 0x9 rather than 2BA1. That predates the switch to SD but its never affected anything for me. The MAF load cap is 378.5 as I recall, so you shouldnt be near enough to that even if you were blowing through the 335 mark a little.
Thanks for the feedback guys. Will try those and report back with results. This is running a MAF too, not SD.
I assume 'load cap fuel flow eliminator' and 'load cap airflow' are tables in an SD rom or something, as I can't see them in my 90550701 XML?
Will try setting the load boost address to 3814 though. |
Originally Posted by todd6027
(Post 11343427)
This is what the XML looked like when I flashed the ECU: Code:
<table name="Fuel Cut Load x1" category="Global Fuel Settings" address="3814" Type="2D" scaling="LoadBoost"> |
this should sort it , should be 600D--->4000 not 4D00 and 3814 for address
<table name="Fuel Cut Multiplier" category="Global Fuel Settings" address="11ac6" type="2D" level="2" scaling="Hex16"> <table type="Static Y Axis" elements="1"> <data>To use "Fuel Cut Load x1" = 0x600D To use "Fuel Cut Load x2" = 0x4000 :</data> </table> </table> <table name="Fuel Cut Load x1" category="Global Fuel Settings" address="3814" type="2D" scaling="LoadBoost"> <table name="RPM" address="56b6" type="Y Axis" elements="9" scaling="RPM"/> </table> <table name="Fuel Cut Load X2" category="Global Fuel Settings" address="3814" type="2D" level="2" scaling="FuelCutLoadX2"> <table name="RPM" address="56b6" type="Y Axis" elements="9" scaling="RPM"/> </table> <table name="Fuel Cut Load Trigger Delay" category="Global Fuel Settings" address="159a" type="2D" level="2" scaling="Time"> <table type="Static Y Axis" elements="1"> <data>FUEL CUT will not engage until the limit has been exceeded for this duration of time:</data> </table> |
Awesome. Thanks Todd :)
Will try it and report back. |
That worked! Thanks heaps mate :thumbup: :beer:
Originally Posted by Eisen7
(Post 11346101)
Todd top man
