Tephra V2 Launch Control problems and inconsistent.
I have been testing the launch control maps and it does what it needs to do for just 2 or so seconds. When i get into LC mode it bounces off the set rev limit then shoots into a free rev and i dont have a rev limit till i turn off the car and turn it back on.
If i get on and off the throttle quickly keeping it in its window it wont do it. But if I hold it or try to, it wont for very long. Has anyone been able to use it consistently as it should? |
i've seen this once before, but ive never really tried to replicate it...
the code is very simple, basically examines TPS and clutch down... i think perhaps the TPS is being pulled back by the ECU. can you log TPS while your doing it and see if that drops below the threshold? |
Originally Posted by xBoostx
(Post 11518354)
Originally Posted by tephra
(Post 11555436)
the code is very simple, basically examines TPS and clutch down... i think perhaps the TPS is being pulled back by the ECU. can you log TPS while your doing it and see if that drops below the threshold? Settings that I remember for that one car tps enable for LC = 50% Speed = 14km/h I just blew it off as maybe there is a subroutine parameter in relation to max rev limit * duration before it disables LC for X amount of time |
Fixed?
