Direction Address
what it the direction address for 9653xxxx and 9417xxxx
The one posted down here its for the 8859xxxx: ////////////////////////////////////////////////////////// table name="MAP Scaling" category="MAPSensor" address="670c" type="2D" level="1" scaling="uint8" table name="MAP Output" address="800e" type="Y Axis" elements="9" scaling="Volts16"/ //////////////////////////////////////////////////////// in the ecuflash this option comes up in the 8859xxxx for scanging the scales of the map sensor but not for the ones I listed 1st |
what is the map sensor calibration used for that the table defines?
in the 3d sd stuff there is a separate table for defining map v to kpa....i think? |
