Max total upward wgdc correction vs tps table issue
I am running V7 rom 88950715, when I try to correct my tps scaling(shown on left) to match the values shown on right the car will not start. I tried redownloading the rom file and got the same issue. Any thoughts?
https://cimg4.ibsrv.net/gimg/www.evo...27b6585656.jpg -David |
If you are just editing them to match then that is wrong. I can't remember which one is wrong the address or scaling but here's a pic of how it should be. It's best to edit the xml file through notepad.
https://cimg1.ibsrv.net/gimg/www.evo...27b6585656.png |
You have the incorrect address and you changed the values. Put them back to what the had before (or start from a fresh rom) and use address="7284" for TPS
Anytime you see scrambled values like that, never change the values, you have a wrong table definition address. |
<table name="Max Total Upward WGDC Correction vs TPS" category="Global Boost Control Settings" address="3f10" type="2D" scaling="OffsetWGDC">
<table name="TPS" type="Y Axis" elements="9" scaling="ThrottlePercentage"/> This table has good scaling: <table name="TPS WGDC Correction" category="Global Boost Control Settings" address="51304" type="2D" scaling="Percent255"> <table name="Throttle" address="512ee" type="Y Axis" elements="6" scaling="ThrottlePercentage"/> </table> Is it just missing the address? So would the below be correct? <table name="Max Total Upward WGDC Correction vs TPS" category="Global Boost Control Settings" address="3f10" type="2D" scaling="OffsetWGDC"> <table name="TPS" address="7284" type="Y Axis" elements="9" scaling="ThrottlePercentage"/> Thanks, David |
When I added the address="7284" the table now has the correct scaling. Thanks.
Rando bump of this thread. I made the same mistake as OP and it basically made my car so it would start right after a flash but about an hour later it wouldnt start. All stemmed from manually changing TPS values in the table when it was gibberish.
Weird symptoms, If you key-on, CEL would not turn off after 20sec. And OBD2 scanner or EvoScan could not connect. But it ECU can still be reflashed. Adding "address="7284"" to the table def below fixed it for me as well. "<table name="Max Total Upward WGDC Correction vs TPS" category="Global Boost Control Settings" address="3f10" type="2D" scaling="OffsetWGDC"> <table name="TPS" address="7284" type="Y Axis" elements="9" scaling="ThrottlePercentage"/> </table> |
