Can anyone identify what country, and spec of this EVO 8 4plug ECU.
Hi everyone. Had to buy a replacement ECM for the 2004 USDM Evo 8, due to blown Fuel Circuit pin 22. My original one was what came in the car from the manufacturer. I verified that ALL U.S. 2004 EVO 8 GSR replacements from factory in US have same part number if you need to replace. The ECU I purchased is a different part number, different specs on the label, and I am assuming different internal memory size. In the picture, my stock one is on the left, and the replacement is on the right. Notice the different specs of both. Yes it is from an EVO 8 4plug, and yes it is currently working. However, I am curious as to what I got. When I recieved the ECM, I read the ROM from it, and NONE of my definitions work. I have the latest definitions to all ECU's in ECUFlash, but this one is unidentifiable. I read it, and saved it, just in case I may need to return the ECM if it did not work due to the spec difference. I was able to load my latest ROM revision to it, and car started. I would just like to know if I have a EURO, AUDM, or JDM ecu in my hands.
https://cimg2.ibsrv.net/gimg/www.evo...9229b274ec.jpg |
1 Attachment(s)
I guess it would help if I upload the ROM I pulled from it. Maybe someone can identify the ROM for me, please.
Thank you. |
2 Attachment(s)
You old one MN191022 is 2004 Evo8 usdm ECU.
Your new one 1860A118 is 2004-2005 Evo8 usdm ECU. You've bought correct replacement ECU just one year newer) You should be able to use it with no problems. ROM image that you've posted above is 94171715 Tephramod V7 Speed Density ROM. I believe something wrong with your xml definitions. Just copy these two files in your ecuflash\rommetadata\mitsubishi\evo folder. |
Yes sir,
Internal ID: 94171715 Inherits: 94170715 |
ROM image that you've posted above is 94171715 Tephramod V7 Speed Density ROM. I believe something wrong with your xml definitions. Just copy these two files in your ecuflash\rommetadata\mitsubishi\evo folder. Yes sir, Internal ID: 94171715 Inherits: 94170715 |
