-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-341/)
-   -   ECU can't read rom (https://www.evolutionm.net/forums/ecu-flash/737784-ecu-cant-read-rom.html)
strykr Feb 26, 2017 08:54 PM
ECU can't read rom
So I installed the latest version of ecuflash and have the 13 usdm ralliart definition which is what I'm supposed to be running but I still can't read the ecu. The only thing I can save is a srf file which I can't read even manually forcing it to read in the Dev option.
Im not sure if I'm missing a step or the program just doesn't like Win 8? I also tried to run the program in admin mode with no luck.
Does anyone have an idea why I'm having trouble?
Thanks in advance.
Edit: forgot to mention I have a 14 ralliart
strykr Feb 27, 2017 04:06 PM
https://cimg4.ibsrv.net/gimg/www.evo...6ed5e6a6a5.jpg
Nobody has an idea? Ive been searching around and cant find anything, directories all seem to be pointing to their proper locations and i have the xml files.
checked using a hexeditor and line 50020 only shows ffffffff
RazorLab Feb 28, 2017 08:46 AM
want to attach the srf file? I bet you have the incorrect definition. What is the ROM ID of the SRF file?
strykr Feb 28, 2017 11:30 AM
I will upload it as soon as I'm off work, but it is 59570004
strykr Feb 28, 2017 03:47 PM
As Requested, the link to my srf file.
https://drive.google.com/open?id=0B2...E5HeEY2Ykd0LWc
psfp Feb 28, 2017 06:33 PM
Your rom id is 5957005.
Download 59570004 from Golden's website and this 59570005, which inherits 59570004 definitions:
https://drive.google.com/file/d/0B-f...ew?usp=sharing
SRF file format offsets things when compared to hex or bin formats. In SRF file, your rom id is located in 50141 address.
strykr Feb 28, 2017 06:40 PM
I have both of those xml definitions and I tried using them with no luck? :(
psfp Feb 28, 2017 06:46 PM
https://cimg1.ibsrv.net/gimg/www.evo...378fe051ee.jpg
Well, it's working here. Show us your xml files.
strykr Feb 28, 2017 06:52 PM
Well.... I feel like an idiot, the 004 file had (1) at the end. Just fixed it and now it works!!
THANKS GUYS!
