Thermo fan sensors
Hi,
Interesting issue happening. When I turn on ACC. with out starting car, my Main Cooling Fan or THermo Fan kicks on, I have noticed it been running all the time now. I have checked all the V7 Tables and looked at settings, and it should not be doing this based on duty and temp. However, also with in my xml definition on the 9417 ROM, I noticed (2) tables that talk about sensor fault and sensor fail... Its doing this with air temps of 60 degrees F or 15 degrees C. Very weird for it to do this. Maybe the fan relay is going out, for it is the stock unit from day one on the car...2004. Can any one point me to what sensors the Main or Thermo Fan runs off of so I can check those sensors for fault? Common sense says Water Temp Sensor, but I can verify that it is reading, I would say rather accurately. I'm just trying to figure out why it is running all the time. Thanks in advance, |
Bump
Your control module is dead. I have a thread about it here:
https://www.evolutionm.net/forums/evo-electrical-audio-security/743349-radiator-fan-controller-bought-farm.html |
Thanks for the heads up. How is yours working now that it has been going on for a year?
Originally Posted by Raceghost
(Post 11834344)
I actually tested both speeds with evoscan a few weeks back and it worked no problem. |
(Post 11834355)
SMH, I always forget about the actuators in EvoScan...lol. DOH!
Hey Biggie, so I just did the actuator test, and both speeds work, though I haven't changed out the module? The fan that turns on when I turn key to accessory is the inside fan, or fan between radiator and turbo. Seems like the actuator turns on the fan between the bumper and radiator. What do you make of this?
Can you share your thermo fan duty tables ?
Can you share your thermo fan duty tables ? Ok, just ran actuator test again. Fan between Radiator and Turbo, no change. Actuator turns on Fan between bumper and Radiator, though it sounds same speed with both High and low actuators, but does turn off and on with actuators. |
(Post 11834573)
I am sourcing one for test, I will get back to you. Thanks
It was the Fan Module. Picked on up from the local Mitsu Dealer today for they just happened to have one in stock. Cost me $250 but they owed me some credit for some trade work, so free 99.
(Post 11834664)
Sorry for bumping an old thread, but if I understand it correctly, bad fan control module can turn on the fan even the engine is not running?
I had a recall for the fan control module, but it was more like 15 years ago already (still under 60,000 miles on odometer though), and mine does similar things now, it stays on even after engine is shut off, and when the engine is warm fan kicks on even before the engine start. But it does not stays on, so I though my coolant temp sensor is going bad, but after reading this, I guess fan control module is the problem. :( |
