94170015 SD rom Where can I find it
So my car is running speed density the rom id I pulled is 94170015 but I can’t adjust any of the SD options the car is already running SD but I wanted to adjust a couple things and I can’t see any of the SD options anyone know where I can get the file for ecuflash? |
I guess I should say I can’t even see any SD options I’m missing a file to add to ecuflash but I can’t seem to find the file for it anyone know where it can be found the car was tuned by English racing |
look in the tephra V7 thread. The XML's should be linked there.
I don’t think it’s running v7 is the problem at least from what I can tell I added all the v7 xml files just to check and opened my rom up but it just looks like a tuned stock rom no tephra options |
Well 94170015 is a stock rom ID so maybe that's why ecuflash isn't loading it as an SD rom. There are actually a few different SD roms floating around so not sure exactly which one your tuner used, but you can try changing the rom ID to 94171715 reloading it and see if the tables show up correctly.
(Post 11865762)
Originally Posted by Evolevos
(Post 11865767)
so under the rom Id or whatever it’s called I just change it to 94171715 save it separate and reload it and see if it opens the SD tune if I’m understanding this correctly right ? |
Okay cool I’ll try it today and report back would there be a reason why though if I have all the files for tephra it’s still just opening as 94170015 I’m wondering if it’s running a older version of tephra like v5.10 is there anywhere to get those files or are they long gone ? |
(Post 11865778)
So I gave it a shot and yes it does open as a SD rom but it’s definitely not the right one my high a tone fuel map reads 7.5 across the board and my timing map shows -1 in every section and it’s not the alt maps those show the same so it has to be a SD rom for tephra v5.10 I know there is a xml file for that version I just can’t find it anywhere |
(Post 11865895)
