Guide: How to flash the Airtrek Turbo
2 Attachment(s)
There is already a lot of good info on this forum for flashing the Airtrek , but its spread across many pages and quite outdated now. These are cars are becoming more popular in Australia and i thought an updated how to guide would be useful.
This guide is not designed to teach you how to tune your car - just get the process working. The best guide for tuning around is probably Merlins - available here What you need Tactrix cable
Connecting the Tactrix cable The tactrix cable comes with two connectors, both of which connect up under the steering wheel. https://cimg1.ibsrv.net/gimg/www.evo...a02fd3b1a9.jpg Unfortunately the reflash connector on the Tactrix cable does not work out of the box. The solution is to add a spade connector - both on the car and on the tactrix cable (if you have the older 1.3 cable you could also re-pin the taxtrix connector to match the car side). https://cimg3.ibsrv.net/gimg/www.evo...854142194c.jpg Below shows the 1.3 Tactrix cable with a spade connector added https://cimg2.ibsrv.net/gimg/www.evo...4a3426856c.jpg Once you have the spade connector added you can read and relfash your ecu! Setting up EcuFlash software (this is based on 1.44 software version) The good news is 1.44 version has the best included definitions for the Airtrek. The bad news is it does not come with correct settings to read the Airtrek ECU - but this is easily fixed! Setting up a custom 'read_template' for the Airtrek Ecuflash uses read_template .xml files to tell the software what setting are needed for different mitsubishi ECU's. Without the correct settings for your ecu you wont be able to read or edit your ecu data. The read templates are stored here C:\Program Files (x86)\OpenECU\EcuFlash\rommetadata\read templates when you load up Ecuflash you will see them under 'select vehicle typehttps://cimg8.ibsrv.net/gimg/www.evo...f59262ac76.png The two settings we need to change for the Airtrek are FLASH METHOD and MEMORY MODEL. Airtrek Turbos always use the memory model SH7055. Depending on the year they may use flash method 'mitsukernal'or 'mitsukernalocp'. Generally the earlier years used mitsukernal and later mitsukernalocp. The flash method is tied to the ecu not to the ROM version (more on that later). I have attached a Airtrek read method to put in the Ecuflash directory. If you select and use this read method and it doesnt work then you will need to change your flash method to ''mitsukernal' by editing and saving the file. ECU Rom downloaded Once you find the correct flash method for your car you should be able to succesfully download your rom and examine it in Ecuflash. The Airtrek has the following possible ROM versions 89970009 (mitsukernal) 89970010 (mitsukernal) 89970017 (mitsukernalocp) 89970010 has the best defined ROM out of all the versions. If you have another version ROM it is possible to flash to 89970010 with no problems. However if your ecu uses mitsukernalocp you will need to change your flash method to match in your ROM xml (otherwise it wont read it). 2 Byte load 2 Byte load is pretty essential for accurate tuning. Attached is the stock 89970010 rom with 2 byte enabled and the EGR disabled. For refrence the 2 byte load values are: the 00 value is 6a36 (decimal 27190) and the 01 value is 6a37 (27191). |
Hey mate thanks so much your a legend.
with airtrecks can i directly flash gta rom or it it better to only change the latency and maf scalings on the stock airtreck rom thanks |
Originally Posted by aj6828
(Post 11929529)
You can flash the GTA rom but be mindful of the differences between the two. Which includes a Latency adder for the injectors, Different MAF scalling etc
https://cimg0.ibsrv.net/gimg/www.evo...94a0d95c1e.jpg |
Originally Posted by scientist
(Post 11931874)
https://cimg0.ibsrv.net/gimg/www.evo...94a0d95c1e.jpg Are you using a custom definition? I'm missing some of those tables |
Yes, I'm using a Custom Rom + Definition
that looks like a awesome rom your using would you like to share the rom and definition with me ? appreciate it ..
Originally Posted by OzAirtrek
(Post 11929570)
Not a problem mate! Yes you definitely can flash the GTA rom. However the MAF scaling, injector settings and gearbox shift settings are different so you need to copy those over
I used some of their sizing from the STi roms as a starting point
https://cimg0.ibsrv.net/gimg/www.evo...79927b71b5.jpg |
So i managed to get a wideband (AEM) installed. The guage was easy enough but getting the serial port loggin to work took some stuffing around. I think it was a bad ground in the end. Anyway it is loggin corrently in evoscan now.
Next task will be installing and tuning some 650 denso injectors. https://cimg7.ibsrv.net/gimg/www.evo...80df11ed1b.jpg |
Got some 650cc injectors in from here.
Got them running pretty close now using this scaling and latency https://cimg3.ibsrv.net/gimg/www.evo...78855b3486.png |
Need help! 2003 jdm airtrek.
Kept getting error message andfailed to read rom. Tried using mitsukernelocp and mitsukernel same result. A friend suggest i need a 32bit XP laptop? Or do i miss something?
https://cimg3.ibsrv.net/gimg/www.evo...f21a04dc28.jpg Spliced the green wire to a 2.5mm jack https://cimg4.ibsrv.net/gimg/www.evo...3d778b2e14.jpg |
Originally Posted by Mahwy1441
(Post 11938495)
https://cimg3.ibsrv.net/gimg/www.evo...f21a04dc28.jpg Spliced the green wire to a 2.5mm jack https://cimg4.ibsrv.net/gimg/www.evo...3d778b2e14.jpg Also check your battery voltage is good.. Can you log data with evoscan or mitsulogger? |
(Post 11938497)
Your don't need xp. Are you using the latest version of ecu flash?
(Post 11938498)
Yea battery was good i got a charger attached. I use the latest ecuflash i just downloaded since i just got the tactrix last week. Haven't tried evoscan or mitsulogger yet since i was just about to disable egr first.
Based on your photos should be set correctly.. possibly your re flash connector is a bad connection? The error is basically saying no response from car ECU is my understanding |
