-   ECU Flash (https://www.evolutionm.net/forums/ecu-flash-179/)
-   -   After Tephra Map car don't start (https://www.evolutionm.net/forums/ecu-flash/761067-after-tephra-map-car-dont-start.html)
Lancer_Evo_8 Apr 2, 2021 01:18 PM
I have the Evo 8 with the OEM Map 96530006. Now i install Tephra V7. When i Flash this to the car, the car don't start. When i go back to the OEM Map it start again. I thought its someting with the Immobilizer. But there didn't foud a solution.
Is there somebody how can take e look. im my two files and give me some inputs. Would be great.
https://cimg2.ibsrv.net/gimg/www.evo...9402162959.jpg
OEM MAP 96530006
https://cimg3.ibsrv.net/gimg/www.evo...41b7947e6b.jpg
TEHPRA V7 MAP 96530706
hutch959 Apr 2, 2021 04:13 PM
turn the immobilizer off... then you will know if thats the problem or not.
Lancer_Evo_8 Apr 2, 2021 11:56 PM
I try it to disable the immobilizer. I set it to 0 and flash it again to the car. But i can still not start the car with the TEPHRA MAP. :(
https://cimg5.ibsrv.net/gimg/www.evo...0ff741f1e4.jpg
Biggiesacks Apr 3, 2021 06:52 AM
You transferred your tune right? Specifically the startup and injector related stuff?
Lancer_Evo_8 Apr 3, 2021 07:27 AM
1 Attachment(s)
im 100% sure that i transferred the file correctly from 96530006 OEM to 96530706 Tephra
It looks like its something with the immobilizer. But there i can't see something wrong.
Because with the OEM Map the car start, with the Tephra Map the engine turn, but he don't start.
In the Attachments i put the 96530706 Tephra Map how don't start. Maybe somebody can find the mistake.
Biggiesacks Apr 3, 2021 07:56 AM
If you disabled the immobilizer, and it still won't start, it's not the immobilizer. I have had a rom become corrupted on me and not start. You could try downloading a fresh rom and transfer the tables again and see if it works. If that's not it then you probably missed something in transferring over your data.
Here is a thread about the tables related to startup that need to be moved over:
https://www.evolutionm.net/forums/ec...cv-tables.html
Lancer_Evo_8 Apr 3, 2021 09:10 AM
I checked now the whole OEM MAP (how can start the engine) and compare it with the TEPHRA MAP (how doesn't start the engine). With the ECUFlash function (compare ECU)
There are some difference between the two maps. But where i can find the difference marked here in red color. Maybe there will be the problem:confused:
https://cimg4.ibsrv.net/gimg/www.evo...9602b064d5.png
Biggiesacks Apr 3, 2021 09:30 AM
The hashes don't really tell you anything. They would be different just from the edits that tephra makes to the oem code. You will need to spot check tables.
Lancer_Evo_8 Apr 3, 2021 11:17 PM
So i checked every single folder of the two Maps.
I found only one difference. The Global Fuel Settings IPW was set to 0x0009. With OEM Injector it has to be 0x4908. What do you think, it can be the Reason that the car don't start?
https://cimg8.ibsrv.net/gimg/www.evo...4f5f12588b.jpg
Biggiesacks Apr 4, 2021 06:29 AM
What about the tables from the thread I linked? They may not be part of your XML and need to be added.
Lancer_Evo_8 Apr 5, 2021 12:58 AM
I checked all your tables you showed me in the thread linked. Everything good. I compare the MAP how don't start the car even with e old one i had from 2013. Even there the only difference was this here.
Now i changed the tables back from 0009 to 4908 & 4900. I will try it today to flash it to the car and look if it start.
https://cimg2.ibsrv.net/gimg/www.evo...7d56874d51.jpg
Biggiesacks Apr 5, 2021 06:40 AM
Those are part of a mod that modifies how the cpu calculates the minimum injector pulse width. You need to verify that the modded minimum ipw value is what the stock value was if using stock injectors. Finding the words to explain this is tough. The mod works by changing the way the ecu interprets the value stored for the minimum injector pulse width. So if you implement the patch and don't change the value, then it will be very wrong. The context behind why you would want to do this is in the other thread you posted in. Since you have the patch implemented you should be using the scalings from the min ipw patch thread to modify the minimum ipw value. If you are still using the stock scaling in your XML to view and edit the value in ecuflash it will be wrong.
Lancer_Evo_8 Apr 5, 2021 08:56 AM
2 Attachment(s)
I flashed the TEPHRA MAP with Stock IPW Value. But the car still don't start. :rant:
Now i downloaded a new Tephra File (96530703) . I will refill the tables again. Maybe it was someting wrong with the tephra-file.
Lancer_Evo_8 Apr 8, 2021 01:54 AM
Its possibile that the car just crank and don't start with this difference in the immobilizer?
https://cimg8.ibsrv.net/gimg/www.evo...4781c0cebb.jpg
Biggiesacks Apr 9, 2021 05:08 AM
I think that's just an XML thing, they are the same numbers just presented differently. If the immobilizer is preventing the car from starting you get a little green flashing key on the cluster.
