Immobilizer Question
Originally Posted by 96_LXR
Check the immobilizer box, then click right on the code to highlight it. Once you click on it it will turn kind of green (you'll be able to tell when it's highlighted). Next hit the "Edit" button to open the menu.
Select "Set Data" from the menu (shortcut is =), you will then get a dailog box to input the code.
Hope this helps,
Bob
Hope this helps,
Bob
Thank god you posted that. I dont think i could have slept tonight w/out knowing.
Thanks. I was going way in the wrong direction. Too bad its 12:40am now.
Originally Posted by SR20DE-T
Where do you find the Immobilizer box. I cant seem to find it on my rom image or my parameters? Does the cable need to be connected to see this?
Go to options and change your access level from beginer to advanced or developer. Now you have the box that says immobilizer
i just got my cable downloaded ecu flash, burnt a copy of my rom to a cd before i email to Al I would like to know how to find my immobilizer code and ecu flash doesnt seem to havethat option. Im sure Im just missing something?
ANYWAY, the Immobilizer value is at a different level than the beginner/basic tuning tables..
Go into OPTIONS, find USER LEVEL, set it to ADVANCED and you should see it show up under the MISC grouping..
Originally Posted by MalibuJack
This has been asked before.. However its not as easy to find the answer to this question.. Unless of course you read the last 5 or so posts in this thread..
" admit nothing deny everything and make counter-accusations"
thanks I actually submitted my post about an hour before the post that answered my question showed up......otherwise I wouldnt have asked. but thank you for being. being here, and being you. Man i was your biggest fan too.
Just having a bit of fun.. I just thought it was humorous because the answer was in this thread..
