When i pull my current map...this is what i see...
Old Jun 11, 2006, 02:59 PM
Sap12687's Avatar
i deleted it (96940011) but i am not promted with anything once i reload the file. Yes i restarted it.
Old Jun 11, 2006, 07:16 PM
DynoFlash's Avatar
Originally Posted by burgers22
Hi
I can read your file using the 96420008 xml deffintion file. If you delete the xml your hex file is currently using, closed ecufalsh & reopen it. The program should then ask you for a new deffinition, from the drop downlist select the inherits from 9642008. Fill out the next set of boxes & it should be done.
MB
There you go !
Old Jun 11, 2006, 07:34 PM
b0ostedEV08's Avatar
Send me the file, and I will disassemble it for you and make a xml definition for it. Send it to my email info@mynesperformance.com
Old Jun 11, 2006, 09:00 PM
Sap12687's Avatar
Thanks boosted you have email!
Old Jun 12, 2006, 04:26 AM
burgers22's Avatar
Hi
You should restore 96940011 from recycled bin. I think you should have a file called JM9694 or similar, I think this is the actual file ecu flash is using, rather than the inherited data.
MB
Old Jun 12, 2006, 05:57 AM
MalibuJack's Avatar
Hey, PM Me if you got any new info, I started disassembling the ROM From my car in IDA Pro and started getting a bit more insight into the software but I don't have the Peripheral functions so I have a hard time telling which input and output are being triggered..
Old Jun 12, 2006, 03:03 PM
File is done, check your email.
Old Jun 12, 2006, 03:05 PM
Yeah you will have to go thru the docs and mark the subroutine so you can remember for the next time. Also add comments for what address of peripheral it's referring to from the docs.
JohnBradley
Mar 20, 2017 08:23 AM
RallySport Direct
EvoX 'For Sale' Electronics / Lighting / Audio
Nov 28, 2016 03:44 PM
inf0
Nov 15, 2016 11:53 AM
andrew_7007
Northeast Region
10
Mar 29, 2009 06:57 AM
evo828
Feb 21, 2008 02:56 PM
Quick Reply: When i pull my current map...this is what i see...
