ECU Flash Results
Originally Posted by elhalisf
is that map that you posted for the race gas or the 91 tune?
also, why so lean at idle and soo much timing?
The Fuel Trims have nothing to to at idle as the car is is closed loop, it will adjust itself to maintain a 14.7 af.
It's pump gas.
NOTE: DON"T USE MY FUEL TABLE!!!! MY INJECTOR LATENCY COMPENSATION TABLE ANDINJECTOR SCALING TABLE HAS BEEN HEAVILY MODIFIED TO ALLOW THE CAR TO RUN ON THE STOCK INJECTORS AT THIS HP LEVEL
