Evo 9 and Lancer Auto support added to V1.28
Old Jun 20, 2006, 05:49 PM
colby's Avatar
EcuFlash 1.28 is out and supports reflashing the Evo 9 as well as ~03 Lancer Automatics (maybe some other years - not sure which). Jason has updated the Evo 9 maps definitions a bit too. I don't have any maps for the Lancers that are supported yet. If you have made up any new XML files yourself, you will need to change the <flashmethod> parameter in them. Any flashmethods that used to be "evo" should now be "mitsukernel"... If you have your rommetadata somewhere other than the install directory, you will need to update all of your files (or just use the new ones) or you won't be able to flash. Sorry for the inconvenience!
EcuFlash 1.28
Old Jun 20, 2006, 06:13 PM
EvoRicer's Avatar
NICE! Thanks Colby and Jason for all your hard work...now I just gotta wait ill I get off work at Midnight...damn...
Old Jun 20, 2006, 06:24 PM
Noogles's Avatar
Damn,
I'm still working on the users guide for version 1.27
Old Jun 20, 2006, 06:36 PM
gsrboi80's Avatar
DL'ed thanks gentlemen
Old Jun 20, 2006, 06:39 PM
jasonc32amg's Avatar
sweet, time to order a cable
Old Jun 20, 2006, 07:32 PM
colby's Avatar
not much has changed that would require updating a manual... yet.
Originally Posted by Noogles
Damn,
Old Jun 20, 2006, 07:34 PM
AlwaysinBoost's Avatar
noticed the first problem... you can't compare values from different maps at the same time. With the previous version you could open up two maps and have say the High Octain timing map opened up on both. Now when you click anywhere except for on the map, whatever your looking at gets sent to the background. know what I mean?
Old Jun 20, 2006, 07:35 PM
andenbre's Avatar
efn awsome
Old Jun 20, 2006, 07:49 PM
gsrboi80's Avatar
Oh that sucks I liked thats. Its how I looked at me and my girls roms side by side
Old Jun 20, 2006, 07:51 PM
getting the following error message when I try to reflash my ECU:
[04:04:34.187] Version 1.28.716
[04:04:34.203] 8 memory models read.
[04:04:34.671] 72 ROM metadata models read.
[04:04:34.671] checksum module "subarudbw" loaded.
[04:04:34.671] flashing tool "wrx02" loaded.
[04:04:34.671] flashing tool "wrx04" loaded.
[04:04:34.671] flashing tool "sti04" loaded.
[04:04:34.671] flashing tool "sti05" loaded.
[04:04:34.671] flashing tool "mitsukernel" loaded.
[04:04:34.671] flashing tool "mitsukernelocp" loaded.
[04:04:34.671] flashing tool "mitsubootloader" loaded.
[04:04:43.343] 262144 byte image read.
[04:04:44.515] Flashing tools do not recognize flash method 'evo'
[04:04:49.625] Flashing tools do not recognize flash method 'evo'
[04:04:56.062] Flashing tools do not recognize flash method 'evo'
[04:05:02.812] Flashing tools do not recognize flash method 'evo'
[04:05:03.734] Flashing tools do not recognize flash method 'evo'
[04:05:07.468] Flashing tools do not recognize flash method 'evo'
[04:05:11.968] Flashing tools do not recognize flash method 'evo'
[04:05:49.359] Flashing tools do not recognize flash method 'evo'
[04:05:55.328] Flashing tools do not recognize flash method 'evo'
[04:06:02.984] Flashing tools do not recognize flash method 'evo'
Old Jun 20, 2006, 07:53 PM
andenbre's Avatar
it works for me you just have to minimize ecu flash and all the maps will be on the desktop
Old Jun 20, 2006, 07:56 PM
I just reinstalled ver 1.27 due to the fact I can't reflash my ECU, so I'm good for a little bit until those bugs get worked out. It may actually be a problem on my end... I dunno.
Old Jun 20, 2006, 08:06 PM
Warrtalon's Avatar
AlwaysinBoost, it looks like that error would be related to what Colby said above about changing <flashmethod> from "evo" to "mitsukernel."
So, we can now flash IXs? Uber.
Old Jun 20, 2006, 08:07 PM
andenbre's Avatar
Colby, If I remember correctly you were planning on integrating datalogging into ecuflash, Is this being considered? I know evo4mad is on the verge of releasing data logging software and I was wondering if this is going to effect those plans.
Old Jun 20, 2006, 08:35 PM
gsrboi80's Avatar
Havent tried flashing to it still waiting on my map "AL" . But I DL'ed the 1.28. So how do I go about changing <flashmethod>?
Quick Reply: Evo 9 and Lancer Auto support added to V1.28
