1.28 now available
A better question is where can you download winrar... www.download.com
Originally Posted by Evoscan
Data Logger Features: EvoScan v0.8
UPDATE:
1) Increased Datalogging Speed!
- Added Log To File option
- Added Log To Screen option
- Added Logging SuperSpeed option
To get maximum speed - Disable Log To Screen, and Enable Logging Superspeed. Less effect is noticed on 2000ghz laptops with a/c power, but slower laptops or laptops running off the battery benefit a lot of speed!
2) Increased Stability of start/stop datalogger.
3) Added AYC Info to Data.xml
4) Added DTC Fault Code Info to Data.xml
5) New Log File Format! - Thanks for all of your feedback on this - results now cross-tabulated with easy to use LogId/Date/Time/Seconds
6) Altered DataItem Calculations:
- Increased accuracy on FuelTrim calcs. (Fuel Trims: <100% (lean) >100% (rich) )
- Fixed accuracy on Timing Adv calc.
- Added DataLog="Y" to xml file for default datalogging items ticked.
- Implemented Multiple ECUs to XML file.
7) Added DTC Trouble Code Support
- DataLog Active/Stored Fault Codes
- Retrieve EFI Fault Codes
- Clear EFI Fault Codes
Added simultaneous WideBand SerialPort Logging Support (untested)
9) Added View Log Files Menu Item
10) Added ABS Info to Data.xml
UPDATE:
