Wastegate duty cycles, target boost
Hi
Have any of you advice about wastegate duty cycles and target boost, using the stock solenoid and ECUflash. I have added a ristrictor to the turbo side of the T piece, so I can now get above stock boost, ( it's about 2.7mm internal diamiter)
With this setup I can spike to 24 psi and hold 20 to the red line, this is a little to much for my stock setup, so I've set target boost to 20psi, now I peak at 21 and hold 18.
Spool up and spike are smooth, but the boost fluctuates quite a bit after this. I think this maybe due to wastegate duty cycle being set at 100. Do any of you have advice on a good starting point for these settings for my almost stock setup in the sig.
MB
MB
Guru
Oct 7, 2009 09:27 AM
fid
12
Mar 18, 2009 02:30 PM
spdracerut
Mar 31, 2007 03:26 PM
