Feature Request?
Feature Request?
Is there any way (like on ecuplus.com) we can do a feature request for ECU Flash?
If so, I'd definately like to see more precision in the tables. What I mean is that I'd like to at least tune to the nearest 250rpm. Also, if I chose to "rescale" the load axis, I don't want the load ranges to become less precise. Basically so far what I'm asking for is larger tables, smaller increments.
Hi
That is not realy a feature of ECUflash, in its editing mode it is really a hex editor ( thought the program as a whole is much more). What you are asking is to reprogram the Mitsubisi ECU code.
MB
MB
well... I have ecu+. Hmmm... so you're saying that Mitsu only has cells programmed every 500 rpm? Sounds like alot of interpolation to me. I dont know anything about the ecu or hex really so I'll take your word for it... but that sounds like a very rough way to lay out fuel/timing tables. Guess I'll deal. So with this "scaling" of the load axis, you all are adding 300 and then how are you determining how all the other cells should change?
