Open Loop Load & Open Loop Throttle
What up folks,
O.K. have some questions on the 03 rom's, should apply to others as well, but I think the 05's and up have more tables than I do...
I've been logging a fair amount of part throttle knock while cruizing around town and on the interstate. It seems to occure at right around 40% TPS. 40% seems to be the sweet spot for my part throttle acceleration. At this point, the ECU is still closed loop and the short term fuel trim (as measured by o2 feedback in evoscan) shows around 80% so it deff closed loop.
I started poking around the Open Loop Load tables and the Open Loop throttle tables. I'm thinking that the load tables are the calculated load required for open loop transition while the open loop throttle are the TPS output volts required for open loop transition. Can anyone confirm if this is correct?
I'm thinking If I adjust the TPS Voltage (via Open Loop Throttle tables) so that I transition to open loop at between 35% and 40% TPS it will solve my part throttle knock...........
I would agree with what you are saying. Is it actually knocking or are you simply recording knock sums and the ECU is sorting it out? Additionally, you may need to richen up these fuel zones or retard the ignition. I played around a lot with fuelling to get rid of my lift off knock, but it was part throttle timing that solved it in the end.
Another thing to consider is that some ECUs use certain load/RPM blocks where the ignition is a bit advanced to base a lot of their octane judgement on/switch to low octane etc. If you "fix" these areas the ECU might not be so sensitive to react overall when there is a need for the low octane maps for example. One instance of this I saw was where the knock control only functioned up to a certain RPM and extrapolated what it had learned beyond that. If you tuned out all midrange knock correction it would then detonate up top. May not apply, just things to think about.
Another point to consider is boost control and dump valve choice. If you have a strongly sprung dump valve and a boost control method that is not compensating well for throttle position (eg ball spring MBC or non-TPS aware boost controller), you can build a lot of part throttle boost. Some people like this because of the crispness, but it is a classic problem with delayed/high throttle open loop thresholds.
Agreed,
The fueling corrections alone won't work in this case though due to the ECU staying closed loop.. It's already pulling down the fuel correction into the 80% range. I am a little worried about pulling out too much timing in the low load areas where this is occuring, 90-110 load, but I suppose in all reality, the stock maps in this region are geared more for emissions and fuel economy rather than performance so I will revise the timing in the affected map areas.
Now, I thought my utec would show me the tps voltage in one of the loggers but it does not. Has anyone mapped out the voltage vs tps position (It will varry from car to car, but I'm looking for some general values. From the open loop throttle table it looks like the votage increases with throttle position.....
Yeah the stock map throttleposition below 4000 is about 30% tps, the higher is about 10% tps.. In your case, your TPS may actually need to be adjusted at the throttlebody.. what does it read completely closed? (I'll look up my log and see what mine does, but its just under a volt)
Originally Posted by jcsbanks
I would agree with what you are saying. Is it actually knocking or are you simply recording knock sums and the ECU is sorting it out? Additionally, you may need to richen up these fuel zones or retard the ignition. I played around a lot with fuelling to get rid of my lift off knock, but it was part throttle timing that solved it in the end.....
So to sum it up, i think it is real knock due to the following factors:
1. IAT high
2. Too much advance
3. closed loop fueling keeping the ratio near stoich.
About 15 in the evoscan logs, have done a voltage check on it yet. with the throttle closed. Interesting thing is from some of my logs, it looks like the transition is around 65% TPS, that is the point in a slow tip in that the o2 correction goes to 100 and stays there throughout the run. From what i can tell, when the o2 correction (aka short term fuel trim) goes to 100 and stay there it means the ecu is running open loop.
I'll try to dig up some more logs when i get home and show you guys what I'm looking at.
It is just an 8 bit ADC display in the logs (although most recent ECUs read at least 10 bits on TPS internally for quality of transient enrichment), 5V=255. Mine is 13% closed, 0.65V IIRC.
Have you substantially changed the induction? If so unless you've rescaled the MAF sensor then you'll be reading a different part of the map - often lower = delayed open loop AND advanced AND lean.
So is that a straight linear interpolation? Looks like ot from your 13%=.65v (.13*5=.65).
In that case the my 03 rom Open Loop throttle tables would translate to :
RPM TPS
500 60%
1000 60%
1500 60%
2000 60%
2500 60%
3000 60%
3500 60%
4000 50%
4500 36%
5000 36%
5500 36%
6000 35.6%
6500 35%
7000 35%
7500 34%
I believe my OBDII logger has always shown 0% TP when the plate is closed. hmmm... Might the ECU set the zero position when the car is started? Kinda like how a XBOX sets the zero of the analog controllers when you plug them in or turn it on. I'll check my logger later this evening.
I know that my ECU switches to open loop at about 27-28%(OBDII value) in the lower RPM ranges.
It is a straight linear interpolation. I've confirmed this with a voltmeter - eg 2.5V is 50% on Evoscan. Whether you choose to work in % of 5V, actual TPS voltage, or 0-255 (where 255 is 5V or near enough depending on the voltage regulator on the TPS - and usually many of the other sensors' supply rail) doesn't really matter. The ECU appears to do no autozeroing using the map or the logs. 100% throttle virtually reaches 5V, 100% TPS on logs.
<geek mode>The other factor to consider of course is that the TPS pot probably isn't linear, but is logarithmic. Also they sometimes sit on a little cam - not looked at my Evo one to see. And then the airflow function for a throttle plate is of course not linear either.</geek mode>
