switching look up table
also, dont forget to delete the undefined.xml file under C:\Program Files\OpenECU\EcuFlash\rommetadata folder
however, all this file does is automatically select the 9640008 identifier for the 9640007 ecu. the real 9640007.xml is not out yet. the only main difference is the idle stepper look-up table where the rpm scaling is off. also, some tables, such as the anti-lags tables are not found.
All of the important data in that Definition works fine, I didnt look at any of the more advanced ones figuring you guys would figure it out, it was just important to get out there because I've seen quite a few roms with this EcuID on them..
cfdfireman1
May 21, 2017 12:00 PM
flyingscot
Nov 27, 2016 04:13 AM
Sheasta
Oct 29, 2015 05:00 PM
