Launch control help!!!!!!!!!!!1
ok guy im having trouble making boost using my stationary rev limiter can anyone help me edit some stuff to build about 10 psi or so? i will send my map apon request. and in no way is this map from dynoflash!
I have mine set for 5000 and 5 lbs of boost I have known someone that has done what your looking for and has gone through rear differentials already....................whats up mr TTP its dave from sport mitsubishi........listen to what scott has to say he lives and breaths this stuff for a living.
Originally Posted by TTP Engineering
Yes, the higher the stationary limit, the higher the boost will be. Honestly over 6000rpms you are playing with fire with regards to your transfercase health as well as your center diff.
I have it set to 5k and I build exactly .5bar, I only noticed about a .1-.2 bar difference between 5k & 6k RPM.
set the rev limit to 5000 and learn to launch correctly there.
Build one of these things... http://www.vfaq.com/mods/ICtester.html
Then disconnect your piping going to the turbo and put this where it was. Pressurize the system to ~10-15 PSI then listen for leaks. Any leaks should cause a hissing sound. Use a spray bottle filled with soapy water if you are having trouble finding the leak.
you know what it doesnt matter cause im going back to iraq again in about 5 days and i will be stupid and blow all my money in this car and my MR2. but 95 percent on the evo for when i go back to pensacola i wont get clowned by the black one
