Safer tune produces more power.
#91
Originally Posted by nj1266
And for the millionth time, I am running 93.xx octane. I will try my best not to put that 91 crap in my car ever again. After I started mixing my own gas and getting 93 octane all the blown out spraks that I was logging as spikes in my AFR went away. The AFR is smooth, the car idles better and fells better. It is only $12 per tank more. No big deal at all.
You can go ahead and tune for 13:1 air/fuel. You may make ok power even on 93 octane. The problem is the real world. The mitsubishi engineers aren't stupid. The stock maps are rich for a reason, to keep things less volitile. The innovative link explains how richer mixtures lower the burn rate. Now, the stock maps are MUCH too rich, I will not deny this (the car has to be able to take a pounding). The problem is if you tune a street car on the edge of volitility with respect to air/fuel mixtures you better be watching (or listening) to the knock every second your in boost. I have my OEM boost guage in my DSM set up to read knock. You'd be surprised how far your "perfect" tune is off from the morning drive to work to the evening drive home. A little boost leak, bum tank of gas, etc.... Tune for the edge all you want, but keeping it a little rich is also a good idea.
#92
Originally Posted by razorlab
Do you understand what kind of timing and boost you would have to use to run 12.5 - 13.1 AFR on 91-93 pump gas every day, in all different weather conditions with no problems? Have you personally sat on a dyno and tuned for these AFRS? I have.
#93
That's interesting, all the Vishnu cars I have logged or retuned don't run 12.5:1. Are we talking at the onset of boost or through the whole 3rd gear?
I also don't see anything majorly different in boost or timing retard compared to others.
Just curious, where is your wideband probe located?
EDIT: I just tried to find all the "Tales from the dyno" postings Shiv has posted in the past but all the dyno sheets with AFRS have been moved or deleted. I know most of those did not show 12.5AFRs. Unfortunatly they are all gone now.
#94
Boy, this thread has went to crap fast.
nj1266, if we wanted to know what Klaus said every second of the day, we would probably just move in with him. Get off of Klaus' bandwagon and just learn to listen to other experienced tuners once in a while. Yes, Klaus is an experienced engineer, but there are people on this board that are engineers and just as experienced as him....even moreso when speaking of 4g63 turbo applications.
Tuning a 4g63 to 12.5-13.1 AFR on pumpgas for a daily driver is just not realistic, in my opinion. For race gas, fine, but pump gas, no way. You will have to reduce the boost a lot, and even then, you are on the edge of safety, as many people have tried to explain to you. We can talk another 10 pages about this and all of the science behind it, but why? Do what you want and then share your experiences if you wish. That's what the forum is about. People are sharing their knowledge and tuning experiences with you, but you just shove Klaus down their throat.
Good luck and keep us posted.
Eric
Eric
#95
Originally Posted by mchuang
With ECU flash out I dont see how people can pay for a base flash, custom tune of course, base flash no point. Stock map is very rich and conservative on fuel and timing. It is so rich that if you set boost at 20-21psi with no taper it will still show rich on a wideband without adjustment (self tested various times). You can also add a few degrees of timing in boost portion and it will still be conservative and you can guarantee yourself +20hp also. It wont be optimal of course because it is not a custom tune(recommended), but I guarantee it will feel much better than stock just like people claim on the base flash and you can do it yourself for free or for just the cost of the tactrix cable to support ecuflash.. I hate the fact that someone can take advantage of freeware for some bs like a base flash which does not incorporate any skill. Custom tuning flash by all means is worthy of payment since the tuner is actually putting their skills to use.
I DON'T however feel comfortable messing with my own timing maps etc. I disagree with your statement that a baseflash doesn't take any skill. I have no idea how to do something simple like that for myself, so paying $50 is a no brainer for me.
#96
Originally Posted by kapolani
I am using the EcuFlash software to flash my own car.
#97
#99
Eric
Eric
I fail to see the danger if I am using 93 octane gas, the timing is retarded to 91 octane gas levels, the EGT is around 800-900 C, the AFR is at 12:1 and there is no knock.
#101
I've been tuning 4G63s for 6 years and gone through a few different approaches to tuning. For the first couple years it was just following what everybody "in the know" was doing, as I really didn't know enough about internal combustion to really form my own opinion yet. It wasn't until I put in a Proefi (precursor to the AEM) and started playing with things on my own that I really started learning. My current approach to tuning is very similar to Malibu Jack's. Here are the approaches I've tried:
1. In 00-01 my tuning was HORRIBLE. Moderate boost, extremely rich AFRs, massive timing advance. Worst approach to tuning ever, it doesn't make power and it's not particularly safe either. This was before widebands were viable as a normal consumer though.
2. 02 was all about running the car super rich still, with very limited timing, but a lot of boost. It was decently fast at least I would just tune with the narrowband for .85-.90, turn my base timing way down, up boost to around 23psi, then slowly advance the cas until I got knock.
3. 03 is when the wideband came into play and I found out I had been running around 10.2:1 for the last few years I then tried to lean it out and found that I couldn't run quite the same boost anymore without knocking, but I was running the same times anyway.
4. Late in 03 I started playing with Proefi, and then switched to an AEM in the spring of 04 (it was easier to talked to other people about with the same software). This is when I finally got real timing control and things got interesting. My first tuning attempts I was running timing completely linearly from low RPMs, I didn't really realize that I should be leaving timing lower around torque peak. I also had a horrible knock threshold map that wasn't helping. This approach was slooooowwww and blew two headgaskets.
5. That fall and winter I read anything I could find on tuning, whether EFI or carb, and then went about methodically testing while making more conservative changes. Through that spring and last summer this is what I came up with as my approach (which has some things set specifically for tuning an AEM, but the concepts apply to any engine):
First step is to tune for a flat AFR. I use boost comp in the AEM, so I'll do pulls at 0psi and get a flat 14.7, then adjust boost comp percentage to get the desired AFR at all the other loads. I'll set 15psi at 11:1 to be on the safe side.
Then I'll set up the knock control. I log pulls at 15psi with extremely low timing, and then set the knock table at .2v above the highest spikes I see. I set up for very aggressive timing retard that goes back to full advance very slowly.
After this is done I'll tune for timing. For a car that has a small to medium size turbo without much lag I'll advance timing in the low end, for larger turbo cars I'll leave it lower to increase EGTs and help spoolup (I'll also leave it around 13:1 during spoolup). I slowly advance timing across the board until I see knock retard in an RPM range, then I'll pull it in the RPM range, and advance it at all other RPMs. What you end up with in the end is a curve, here's a completely made up example:
2.5k 5 degrees
3k 6 degrees
3.5 8 degrees
4k 9 degrees
4.5k 7 degrees
5k 4 degrees
5.5k 8 degrees
6k 11 degrees
6.5k 14 degrees
7k 17 degrees
7.5k 18 degrees
That isn't off any particular engine, just numbers to give you an idea of what the curve looks like. Your lowest timing advance will end up being at peak torque. Timing below peak torque stays slightly more conservative, then it dips hard at peak torque, and climbs aggressively past peak torque as cylinder pressure drops off.
I'll keep timing about 1 degree lower than the knock threshold on pumpgas.
After this I'll raise the boost pressure to the next load point on the boost comp table, usually 19psi, and verify that the AFR is the same as it was at 15psi. After that I'll make sure that the boost comp % rises linearly from 15psi up.
Then I copy and paste the 15psi timing map, pull out three to five degrees of timing, and slowly advance it back until knock becomes apparent.
Keep on repeating these steps raising the boost pressure, once you reach a point where timing is running extremely low to avoid knock and EGTs start getting really hot you need to back off on the boost.
OH YEAH OFF MY TANGENT AND BACK ON THE SUBJECT
I've tried a lot of different AFRs, high and low timing, high and low boost, and in practical purposes from my experience AFRs, in a range, do not account for much change in power. As a rough rule of thumb here is what I have seen:
Richer than 11:1 and power drops off
11:1-11.5:1 and power stays high, but it is more forgiving to changes, ie the car is less susceptible to knock being daily driven
11.5:1-12.5:1 power is damn near the same, I haven't seen much point in going to 12.5:1 because the difference in power was miniscule. This is on a car making ~600whp on racegas on the dyno
12.5:1-13:1 Required even less timing advance and did not make more power than 12:1 with more timing
On pumpgas I'll run cars around 11.3-11.5, on racegas 11.8-12.
The key to power in my experience is getting the right ignition advance, cam profile for your particular setup, and the right centerline for your cam and desired powerband. AFRs don't have a huge effect in my experience and trying to run a car in the "best AFR range for power" is just not worth the time.
Oh and another tip, sometimes past peak torque you CAN end up running overly advanced timing to the point of choking power.
2.5k 5 degrees
3k 6 degrees
3.5 8 degrees
4k 9 degrees
4.5k 7 degrees
5k 4 degrees
5.5k 8 degrees
6k 11 degrees
6.5k 14 degrees
7k 17 degrees
7.5k 18 degrees
#102
Nick, good post. What you've learned in the past few years is exactly what I've learned in the past few years. The only real exception is that I started with a pocket logger and instead of getting a standalone I did the ecu chip editing thing.
#103
NDgsx,
Great post....pretty much exactly how I do it and correlates with my experiences, also. The only difference is that I have used DSMLink and a wideband, so I sort of had a 'head start' on tuning with such a great product and board to help along the way. Thanks for sharing your experiences with this board. It's always good to have real world data and not just theory when it comes to tuning.
Eric
Eric
razorlab
5162
Nov 18, 2023 07:52 AM
GST Motorsports
Aug 4, 2023 04:34 PM
