ECU Can handle at least 3000hz
Okay.. In the process of calibrating my blowthrough MAF, I hit 3004hz and the ECU is correctly processing it and associating load with it..
I thought you guys would get a kick out of hearing that.. This was at 20psi and 6919rpm.. I have to do some more work calibrating the curve since I have normal values up to that point now..
Anyway.. look at the capture, its just amusing..
FWIW I'm working on an ignition problem right now, hence the reason its not resolved yet..
I didn't post the evoscan logs, only because their not very useful (or offer anything other than the load cells it falls into) but at 3000hz the car was indicating the 320% load site at around that point.. Obviously very high for 20psi, but a good indication that the ECU can handle the output without a problem. I'm curious if a stock meter even reads 3000hz or higher though.. I have not yet been able to get it to read accurately over 2500hz without it jumping all over the place.
When the stock meter stops registering, you know it! Its called MAF over run and early DSM's know it well. What usually happens is the Hz signal drops to 0 and then starts registering again. Due to the design of the meter the karmon vorticies are not produced avove a certian flow level and can't be picked up by the sensor. The car will lean out, IPW starts getting choppy, and inevitably the knock sensor saves your ***. Its kinda like fuel cut but a little less violent.
Originally Posted by C6C6CH3vo
That's quite a volume of air and load for 10.0 A:F, 20 psi, and 13+ degrees at 6900RPM
The reading is artificially high at the moment, but I posted the image to illustrate that the limitation is the MAF and not the ECU, the ECU will function correctly at over 3000hz and therefore you can tune a 600+ whp car with a stock ECU... Not only that but the ECU can handle 1600cc injectors, since the injector scaling value is arbitrary and doesn't reflect the injector size all that well once you go over 780cc's you can find a workable scale and latency setting for nearly any injector.
The only thing I can think of to watch for is an injector cap like on 1g and 2g ecu's. At a certian gram/rev the ecu in the DSM's would clamp the calculated load and your fuel injectors would flatline.
I'm a Dsmlink user and it's a common upgrade for us to use the Evo maf sensor. It will accurately measure about 25% more airflow before it overruns, compared to a 2g Dsm maf sensor. That's usually around 3000-3400 hz. As for the ecu, the 2g Dsm ecu will handle about 7800 hz while still putting out correct IPW's. I would think the Evo ecu would be similar.
I don't know much about how these things work but I know with all of the advancements made by the Yahoo DSM ecu usergroup, and the Dsmlink guys they have the Dsm ecu's figured out pretty well. Hopefully the same thing happens with the Evo ecu in the next couple years.
There are a couple of Dsmlink powered vehicles running 9 flat in the 1/4, one of them on really low boost(around 25 psi). So the people that say these stock ecu's aren't capable, don't really know what they're talking about. At some point you guys will have the code all figured out and everything will fall into place.
