EvoScan V.90 Is Ready
#183
Anyone know how to make the data freeze so that you can scroll back and forth and look at the values? The only way I have seen to review it so far is to click playback but then I end up playing it back like 20 times because you cant look at everything at once while its playing.
#184
Thats actually why a tool like Data Log Lab is important.. It represents the data your looking at in a way that you can easily spot what your looking for.. then highlight it, and see all the values you need.
I'm assuming you aren't really talking about freezing data while your driving.
#186
www.dataloglab.com
You need to download the Data Analyzer tool fo Evoscan 0.9 from my website www.aktivematrix.com to alter the logs and put the load calculation in for you.. It also includes a evoscan.txt definition file that you use with DatalogLab to import the files..
It sounds more complex than it is.. Once you get a "system" down it's a 2 minute thing..
Data Log Lab is not a free program, but it has a 30 day evaluation you can play with to see if you like it.. I've used the program for several years already, I started using it with the UTEC and worked with them to get it to support the Evo UTEC.. Now they have a universal reader (hence the evoscan.txt file)
#187
If you load the Evoscan logs directly into DLL, it has some trouble with the timestamps.. hence the original reason I wrote the log analyzer..
Hopefully the new version of Evoscan will resolve the timestamp problem along with include load in it.. It will mean you no longer need to take an extra step..
Worse comes to worse, you can use my logger tool instead when I release it for wide beta testing.
#193
Get it here: http://www.limitless.co.nz/EvoScan/
Red Dragon
Jan 2, 2010 01:06 PM
FastAzzEvo
Oct 22, 2008 02:34 PM
