Heading to dealer, got questions...
I'm heading in to the dealer on Wed to get my ACD checked out since all 3 lights came on yesterday. Question is, when they plug in the MUT tool to check, will they need to access the ECU itself or is the ACD seperate from that? If they need to access it, since my ECU is locked, how do I get it back to a stock flash? Will someone elses stock IX GSR flash work or am I SOL? If it can work, anyone got one I can "have"? Thanks for any help.
Tony (REALLY needs to learn ECU-type stuff)
If you want to flash back to stock you will probably need to use MJ's unlocker tool to grab the immobilizer code off your current ROM, otherwise you won't be able to start the car with your copied stock flash.
As long as they don't intend to reflash the ECU it won't be a problem.. the ACD adjustment is done with the MUT tool and it should be able to communicate with the ECU to do that stuff.. The only time you would need to be concerned is if they needed to reflash the ECU for any reason.
This reminds me, is there a way to log the telemetry from the ACD via something like your logger or evoscan?
So it would be a good idea to unlock and go back to stock beforehand. Would I be able to save my Dynoflash map and reload it after they're done?
Alright, DL'd the unlocker tool. When I opened up ECUFlash (I have 1.28) it gave me this message...
[22:09:14.828] Version 1.28.716
[22:09:14.843] 8 memory models read.
[22:09:15.093] 71 ROM metadata models read.
[22:09:15.093] checksum module "subarudbw" loaded.
[22:09:15.093] flashing tool "wrx02" loaded.
[22:09:15.093] flashing tool "wrx04" loaded.
[22:09:15.093] flashing tool "sti04" loaded.
[22:09:15.093] flashing tool "sti05" loaded.
[22:09:15.093] flashing tool "mitsukernel" loaded.
[22:09:15.093] flashing tool "mitsukernelocp" loaded.
[22:09:15.093] flashing tool "mitsubootloader" loaded.
[22:09:15.093] error loading FTD2XX.DLL
What's the error all about?
I'm trying to find the immobilizer code so I can us another stock IX's map, but I don't know where the hell it is. I switched the user level to developer but still don't see it. Where is it?
*EDIT* N/M, found it.
98autogstspyder
657
Apr 27, 2022 01:48 PM
btownevo
Jun 27, 2010 10:35 PM
