ECUFlash / Evoscan / Mitsulogger Questions
#961
Okay, started logging, found the button...but nothing shows up when I click it? It looks as tho there should be a list of actuators to pick from in some sort of menu, but there's nothing there...just a blank menu. Is there some sort of add-on i should be installing? Or maybe an older version of evoscan...?
#963
Before anyone asks I have tried just about everything I could find on Evom. I am using windows 7 and just purchased a brand new 1.3 cable it worked fine to read my original rom but now that I want to write or even read I get the following error. I did not change a thing since I pulled the original ROM. I tried boosting the battery voltage but I will not start the car and try that route because I need to establish a startup tune.
[15:14:52.487] EcuFlash Version 1.42.2595
[15:14:52.487] OS Version Windows Vista
[15:14:52.488] Qt Version 4.5.0
[15:14:52.523] 56 memory models read.
[15:14:52.527] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[15:14:54.089] 343 ROM metadata models scanned.
[15:14:54.089] checksum module "subarudbw" loaded.
[15:14:54.089] checksum module "mitsucan" loaded.
[15:14:54.090] flashing tool "wrx02" loaded.
[15:14:54.091] flashing tool "wrx04" loaded.
[15:14:54.092] flashing tool "sti04" loaded.
[15:14:54.093] flashing tool "sti05" loaded.
[15:14:54.093] flashing tool "mitsukernel" loaded.
[15:14:54.093] flashing tool "mitsukernelocp" loaded.
[15:14:54.093] flashing tool "mitsubootloader" loaded.
[15:14:54.095] flashing tool "shbootmode" loaded.
[15:14:54.111] flashing tool "shaudmode" loaded.
[15:14:54.112] flashing tool "subarucan" loaded.
[15:14:54.113] flashing tool "mitsucan" loaded.
[15:15:00.434] Using interface OpenPort 1.3 Universal TX2DoYFWa93a3ff124e1ef7c31966cb145779d0f09890121
[15:15:02.527] sending init sequence 1 (0001)
[15:15:05.780] sending init sequence 1 (0003)
[15:15:09.033] sending init sequence 1 (FFFF)
[15:15:11.763] no response to any known code
[15:15:11.768] interface close
#964
I have an AEM wideband serial>usb, I can log the wide band external but it only reads it for a bit secs then it randomly stops and freezes on the last afr reading.. evoscan still works fine, only the "external wideband" section locks up.
does anyone know how to fix this? ive tried v2.5 v2.6 v2.7 and v2.8 and they all do the same. I'm using windows 7, would that be affecting anything??
#965
Hi,
i have a problem when i scan ACD/AYC for code on a evo ix. All code appear. I have instal a new ACD pump and a rebuild transfer case and all 3 light of ACD appear when i run my car in first speed and other speed. I Bleed the systeme again and again. I have no air in the system. I would scan for seach a problem. My setup is a 1.3u cable from evoscan and evoscan v2.8. My pc have windows vista. Help me plz.
#966
i feel your pain.
-uninstalling ecu flash
-reinstalled
-now i'm going to try an older version if available, i'll keep you updated.
#969
Same issue here, any ideas?
I have been running Power FC for 6 months and now I would like to go back to stock ECU
I dont remember my rom ID
Any input would be appreciated!!
[00:03:55.686] EcuFlash Version 1.42.2595
[00:03:55.686] OS Version Windows Vista
[00:03:55.686] Qt Version 4.5.0
[00:03:55.706] 56 memory models read.
[00:03:55.706] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
[00:04:01.173] 343 ROM metadata models scanned.
[00:04:01.173] checksum module "subarudbw" loaded.
[00:04:01.173] checksum module "mitsucan" loaded.
[00:04:01.174] flashing tool "wrx02" loaded.
[00:04:01.174] flashing tool "wrx04" loaded.
[00:04:01.175] flashing tool "sti04" loaded.
[00:04:01.176] flashing tool "sti05" loaded.
[00:04:01.176] flashing tool "mitsukernel" loaded.
[00:04:01.176] flashing tool "mitsukernelocp" loaded.
[00:04:01.176] flashing tool "mitsubootloader" loaded.
[00:04:01.177] flashing tool "shbootmode" loaded.
[00:04:01.199] flashing tool "shaudmode" loaded.
[00:04:01.199] flashing tool "subarucan" loaded.
[00:04:01.200] flashing tool "mitsucan" loaded.
[00:05:53.151] Using interface OpenPort 1.3 Universal TX2ASVR05c3a3ff139dbf10dfded3338a3749d27cea89403
[00:05:56.406] sending init sequence 1 (0001)
[00:05:59.638] sending init sequence 1 (0003)
[00:06:02.869] sending init sequence 1 (FFFF)
[00:06:05.599] no response to any known code
[00:06:05.599] interface close
[00:07:51.744] Using interface OpenPort 1.3 Universal TX2ASVR05c3a3ff139dbf10dfded3338a3749d27cea89403
[00:07:54.366] sending init sequence 1 (0001)
[00:07:57.598] sending init sequence 1 (0003)
[00:08:00.830] sending init sequence 1 (FFFF)
[00:08:03.560] no response to any known code
[00:08:03.560] interface close
[00:08:17.421] Using interface OpenPort 1.3 Universal TX2ASVR05c3a3ff139dbf10dfded3338a3749d27cea89403
[00:08:21.449] sending init sequence 1 (0001)
[00:08:24.681] sending init sequence 1 (0003)
[00:08:27.913] sending init sequence 1 (FFFF)
[00:08:30.643] no response to any known code
[00:08:30.643] interface close
#972
can you start the car? then connect the reflash connector? as this should then stop the car if not then you might have a break in that wire. did you cut any wires to fit the FC?
#973
^^actually this is myh friend evo 8 But He bought used. He blow his entire motor and When he rebuild motor and use stock ECU the car could not start at that time. So he switch to Power FC for awhile and now I tried to use his stock ECU last night and I coould not get it works. The car could not start when I put stock ECU ? but If I switch to FC the car was just fine.
any idea would be apprecited !!! Thank you in advance
#974
Is there a ROM swapping for beginners thread somewhere? I just can't figure out what to paste where to get the tables to show up in ECUflash when I open my ROM.
