ECUFlash / Evoscan / Mitsulogger Questions
Old Jan 25, 2014, 05:51 PM
  #1471
CDrinkH2O's Avatar
Originally Posted by jayg4u
Hello all,
I recently installed ecu flash/ evoscan on my laptop and I am having some issues. The day I installed it, it took like 3 install/uninstalls to get everything running. I logged 3 runs so I figured it was good to go. Today I plugged in and get nothing...just says "No Vehicle interface" on ECU FLash. Evo Scan says
"Error: OpenPort 1.3U USB Cable Not Responding, perhaps select OpenPort 2.0 if you have that.
Info: Datalogger Ended
Its almost like its not recognizing the drivers so I re-installed the 1.3 tactrix drivers 3 times...still nothing.
using windows 7/ 1.3U cable and latest of both programs
Im totally fustrated any help would be great....thanks
Could be a bad cable. Find someone who has a working software stack and try your cable with their setup. If you get the same message it's probably a bad cable. Alternatively borrow a known good cable to check your software set up.
Old Feb 6, 2014, 09:55 AM
  #1472
D-VO's Avatar
Hey guys. I'm still unable to successfully log fuel trims on evoscan 2.9 while using the speed density 94172715 ROM. I've tried switching cables from tactrix 2.0 to tactrix 1.3, and resetting the ecu by disconnecting the battery. A few months ago it was static at 0 for all trims, now its static -10 for low, -12 for mid, 0 for high and every once in a while it shows -12 in the "in use" column. I've already thrown a P0171 code which shows the fuel trim too rich, and the wideband readings are varying from 11.5 - 12.3 at 290KPA_Load 3750 RPM, so I'm a little stuck here. Any help would be amazing right now.
Old Feb 9, 2014, 12:09 PM
  #1473
Iceman153's Avatar
Has anyone tried to flash a stock JDM Rom File on their USDM EVO 8? I found an 04 FQ300 rom file and was thinking about using it on my 05 USDM... any thoughts?
Old Mar 4, 2014, 03:40 PM
  #1474
tractionlescolt's Avatar
evoscan issue
evoscan issue any help greatly appreciated!
«**March 03, 2014, 06:56:50 pm »
I just finished getting my turd bolted together after it sitting for a few years. I have gotten my colt to start on the evo8 blackbox using evoscan/ecuflash but i am running into issues with evoscan so i am hoping someone here can help me figure this out. When i open evoscan and push start logging it says to select an ecu from the pull down list when thats where the issue is i have nothing but evox selections this is the list i see :
Evox can mutIII
MODE23 2011 audm evox
Mode23 jp/eu/au evox
Mode23 2009 jp/eu/au evox
Mode23 rs jp/eu/au evox
Mode23 2010 jp/eu/au evox
Rax fast logging-rev e evox
Mode23 usa evox
Mode 23 ra evox
Mode23 us mr/lancer ra evox
Mode23 2011 usa mr/gsr evox
Mode23 2011 usa gsr evox
Sst transmission evox
Can obdII.
So my question is how do i get more selections or which one do i use with the 04 evo8 ecu?
I need to figure this out asap because when select start logging it connects but shows no values the only ecu selection that i have tried is mode 23 usa evox. If it is easier for someone to text me hit me up that way 8014149255
Old Mar 4, 2014, 03:53 PM
  #1475
10isace's Avatar
Do you have a 1.3 or 2.0 cable? Choose the correct one. Then in the middle select EFI.
It needs to look like this:
Old Mar 4, 2014, 04:01 PM
  #1476
I have no efi option thats what i mean its like i am missing ecu selections i am using the op 2.0 cable. I have tried uninstalling and reinstalling a few times i have tried installing older versions still no dice. I am using 2.9 also if that helps
Old Mar 4, 2014, 04:17 PM
  #1477
10isace's Avatar
Did you check Misubishi MUTIII?
Put up a picture.
Old Mar 4, 2014, 04:20 PM
  #1478
Treyzian's Avatar
Old Mar 4, 2014, 04:53 PM
  #1479
mlyman1989's Avatar
Accidentally hit write to ecu before saving immobilizer info.
Was wondering if anyone would be able to assist in a map with it disabled. Would be much appreciated. It is for a 2005 evo mr. Also if possible with tephra mod map switching.
thanks in advance
mat
Old Mar 4, 2014, 06:21 PM
  #1480
Wow i am officially the village idiot! Solved that problem ill check tomorrow to see if when i log values show up! thanks for the help guys sorry i am a newb at tuning and so far openecu has been kinda a pain in the *** but ill post tomorrow after i try to log. thanks again
Old Mar 5, 2014, 08:31 AM
  #1481
aferalo's Avatar
Hey Guys,
im new to the tuning world. im not going to attempt to even do it myself. I have a buddy that is in the know with the evos, he said without a dino that he would not want to tune my evo. Unless I could find a email tune. I found the shop that sells them, but for that price I could have it done on the dino at the shop. is there anywhere I could find these? I have a 05 evo 8 standard edition.
sorry if this is a stupid question, ive tried searching and reading fourms
thanks for any help
Old Mar 5, 2014, 08:46 AM
  #1482
adiszep's Avatar
Hello. I've searched all over this forum and can't find info if EcuFlash or MMC with Tactrix cable reads/writes the EU Mitsu Colt CZT? The evoscan.com site says that it should work but did't find anything to confirm this. Guys help me with info coz i'm in desperate needs
copy paste from the evoscan site:
Mitsubishi ALL Ralliart Colt Turbo / CZT Colt ***NEW*** 2006+ M32176F6 2.0 1.3D/R/U/2.0
Thanks everyone !!
Old Mar 5, 2014, 08:59 AM
  #1483
10isace's Avatar
Originally Posted by aferalo
Hey Guys,
thanks for any help
You can search here: https://www.evolutionm.net/forums/ve...ng-review-176/
And here: https://www.evolutionm.net/forums/ev...g-results-299/
What are your mods and what kind of tune are you looking for?
Old Mar 5, 2014, 03:43 PM
  #1484
aferalo's Avatar
thanks for the links
as far as the mods i only have a intake and a catback. im looking for somthing mild as i do drive it daily. i would be willing to go more aggressive but i worrie about life of the car and would it be as reliable?
thanks again
Old Mar 10, 2014, 06:38 AM
  #1485
wxfede's Avatar
Hello!!!
I'm a new user...I need help!
I'm looking for a tool that allows me to read and write mitsubishi and subaru ecu's. i searched on the web and i find the evoscan tool but there isn't any contacts for ask questions..
is there somebody that can help me to find this tools and gave me some information?
Thank you so much!
Quick Reply: ECUFlash / Evoscan / Mitsulogger Questions
