FTDI time-out?
FTDI time-out?
I keep getting a FTDI timeout on Evoscan v.99 no matter what I do. Version .97 worked just fine. I have the timeout at 500 and the baudrate at 9600. It says that it connects then instantly times out. It will start to log a number then freeze, after 2-3 minutes I'll have a log of 7-8 frozen numbers that arent even correct. Such as idle will freeze at 7000rpm and my TPS will be at like 97, while at idle. I really need some help figuring this out as I am heading to the track next week.
Mine is v.99, timeout is 500, baud rate is 15625? I had to uninstall v.97, then delete the folder.
Installed v.99 and the first time I used it it had to install the drivers and works fine.
Good luck
Good luck
I tried to set my timeout to 1000, but it wouldn't stay. The last run I did worked, but then when I tried to look at the file in DLL my WBAF didn't show up... but it did in evoscan.
I went back to .97 for right now, I needed to check my knock counts w/ new plugs... everything worked fine.
2007, wow! Any additional info regarding this problem? I seem to be having this problem. I can't even log one item w/o getting a time out within 10 sec.
I'm in the middle of reinstalling Win 7 hoping it fixes the problem.
EvoXMR2
Aug 23, 2012 04:50 PM
