cant log load calc after 2 byte load mod
Ok here the deal I cant log load calc in evoscan. Every since I started using the 2 byte load. When I tried to log it today it say infinity? Any ideas why? I have ipw, arf map , and battery checked in evoscan. Isn't that all the load calc is for the calculation?
I'm thinking it's because they both use the same Request ID ... even though I have no idea what the request ID's are for or what they do. It would make sense that you couldn't run both at the same time.
The only other thing you should check is that the LoadCalc formula is below the values it uses to calculate in your data.xml file.
You can log both loadcalc and 2 byte at the same time. LoadCalc is exactly what it says it is calculated load based on other values from the ECU so we aren't asking the ecu for this value as we do for the 2 byte load value (basically what I understand the requestIDs to do).
I log both of them just fine .
My 2 byte load has always worked. I never had an issue with it. I understand 2 byte is more accurate and I will keep using that. Heres the deal. I just installed cams and I want to see what the difference in load is. I do not have any logs of 2 byte without cams. Thats why I am trying to get it work. I will post the line in the xml for load calc later tonight
