PATCH: CEL Flash on Loaded Knock
Old Aug 7, 2007, 05:21 PM
  #31
A418t81's Avatar
+1 70008
Old Aug 7, 2007, 05:35 PM
  #32
tkklemann's Avatar
OK, just to be 100% sure before I do this, I copy the definition into the .xml file, and then transfer EVERYTHING I have modified (Maps/Map values/Scalings etc..) on my current ROM to the one I downloaded from above, (0011 ROM) correct?
Old Aug 7, 2007, 07:20 PM
  #33
tephra's Avatar
Updated first post with FAQ
Originally Posted by JohnBradley
Dave,
One thing I noticed last night when I was tuning for my S1's is that if I waited for the CEL to stop flashing BEFORE I started the car back up it would stay off. If I started the car immediately it would stay on for the 1.5-8 mins that it does when you initially flash and change the ROM so significantly.
Hrmm, the only thin I can think of is you flashed in between these tests, and when you did the flash my memory address was overwritten with a larger value... EcuFlash only updates the needed chunks of code, which is why it takes longer to flash significant ROM changes.
Originally Posted by Ads77
good work Dave , would love this for the 88590014
You mean 88580014? Working on it ..
Originally Posted by kreionic
Second this question. Are we changing all the values that you have in your bin in the mods section? Or just the time and we can set the load, knock, etc.. to our liking?
What other variables are there to change? The first post FAQ has details about each of the tuning knobs.
Yes
Can someone email me a STOCK 94170008? tephra @ gmail
Old Aug 7, 2007, 07:59 PM
  #34
Jumperalex's Avatar
94170008
+1
Old Aug 7, 2007, 08:23 PM
  #35
occultworks's Avatar
94170014
Old Aug 7, 2007, 08:38 PM
  #36
cpoevo's Avatar
You got mail.
Old Aug 7, 2007, 08:39 PM
  #37
tephra's Avatar
thanks!
Old Aug 7, 2007, 10:17 PM
  #38
tephra's Avatar
94170008 is up - UNTESTED, please let me know if it works as expected!
Old Aug 7, 2007, 10:29 PM
  #39
tephra's Avatar
Originally Posted by Dr. Nick
Is it possible to flash the CEL when a certain RPM threshold is met as well, for example, a shift light?
Hi Nick, sorry I missed this one.
Yep I thought about that - I may do it...
However having a CEL flash mean two different things may be bad, I would also prefer not to distract the driver too much as well - especially at speed
what are other peoples thoughts?
Old Aug 7, 2007, 11:49 PM
  #40
Pd1
Pd1's Avatar
I agree with you, tephra. CEL = something wrong. Don't confuse me.
If you want to make a shift light, how about illuminating all 3 of the traction control setting lights (i.e. Gravel, Tarmac, Snow?)
Old Aug 8, 2007, 12:10 AM
  #41
tephra's Avatar
Yep unfortunately we (disassembly community) don't think the ACD/AYC computer is accessible via the ECU. So i'm not sure its possible yet!
Old Aug 8, 2007, 05:56 AM
  #42
dudical26's Avatar
Are there any other lights on the dashboard that are accessible from the ECU?
Old Aug 8, 2007, 06:07 AM
  #43
Dr. Nick's Avatar
I hadn't thought about it from that perspective because I would just use it for the shift light and not both at the same time. I can see where that'd be confusing. In competition a shift light would be more beneficial to me, and I'd always be a reflash away from monitoring knock. I have more faith in my tuner than keeping my eyes on the tach.
If it's easy to do I'd appreciate it but don't go too far out of your way just for me.
+1 for 94170008
Old Aug 8, 2007, 07:40 AM
  #44
fasterthanurwrx's Avatar
Well, being a long time UTEC user, the flashing CEL is something I really do miss now...
If the car is going to knock it’s going to do it mostly likely during WOT. I’m not sure about everyone else, but during WOT on my car I take a peak my wideband, boost, rpm/speedo. So I think keeping a eye out for a blinking check engine light won’t be such a distraction.
Old Aug 8, 2007, 07:53 AM
  #45
20psiMR's Avatar
David, tried 88590015 and works like a champ. I tested on a flash that I know knocks pretty well, and it flashed like crazy. Then tested it on a tune that I get a couple counts here and there, and I set it up to only flash on 5 counts or higher. No flash at all, and logs showed highest count was a couple of 3's. So functions perfectly for me.
When I initially flashed the car, I got the blinking CEL for 8 mins. I just drove around with it blinking and it went away. Ive flashed about 5 more times now, and its stayed off. It only blinks that first time to bring the count down like Dave said. I was worried it would do it on every start up or after every reflash, but it doesnt. HUGE THUMBSUP DAVE!!!
Quick Reply: PATCH: CEL Flash on Loaded Knock
