The list of current ROM modifications
The list of current ECUflash ROM modifications
2-byte load
https://www.evolutionm.net/forums/sh...d.php?t=272246 [Evo 8]
https://www.evolutionm.net/forums/sh...d.php?t=261465 [Evo 9]
https://www.evolutionm.net/forums/sh...d.php?t=293617 [mitsulogger xml def]
2-byte airflow
https://www.evolutionm.net/forums/sh...d.php?t=240981
2-byte RPM
https://www.evolutionm.net/forums/sh...d.php?t=297483
PSI-based boost control
https://www.evolutionm.net/forums/sh...d.php?t=293981
Load-based boost control
https://www.evolutionm.net/forums/sh...d.php?t=288408
CEL flash during knock event
https://www.evolutionm.net/forums/sh...d.php?t=287918
JDM MAP sensor
https://www.evolutionm.net/forums/sh...d.php?t=259595
Lean Spool enable/disable
Evo 9 idle speed adjustment tables
https://www.evolutionm.net/forums/sh...d.php?t=279359
Let me know if I missed anything.
2-byte airflow
2-byte RPM
JDM MAP sensor
Current ROM modifications
I believe there was a thread on setting the IX idle speed for A/C on, A/C off and coasting idle. IIRC, there were new table definitions for making changes in these idle speed values.
The link for the idle speed adjustment in your first post is not correct, just a heads up.
Should be this
Should be this
